InnovaTehno.eu Free Energy Device - a big Fake or the real thing ?
Started by hartiberlin, October 31, 2016, 08:35:37 PM
ARMCORTEX
I follow you on those words NR..Info is treacherous, because researchers don't give easy answers and units of propaganda gatekeepers have layed their traps, many countries I believe understood how easy it is to trick layman who seeks infinite energy. This is to be expected tho...
But it appears that Innova device appears to be real?
You lost me there...
It appears to be fake from all standards of reason. I just continue to believe in it because I am optimistic and persistent, but I really  shouldn't.
And IKNOWNOTHING, isn't tipping the scales for me at least.
But I'm curious, what circuit and setting caused your claimed injury or illness. Can you show the circuit or setting?
nelsonrochaa
Quote from: NRamaswami on March 15, 2017, 11:52:43 PM
Almost all info is inaccurate or misleading. No one gives real info either out of fear or greed.
I have seen real principles to be disclosed only in two pages on net as abstract principles. I know of some people who are very competent but who do not bother about forums. It appears that This innovo machine is real. It also appears that Don Smith had a working device but it produced extremely inimical radiation and so was sort of banned. Any device that uses open core is said to produce inimical radiation. All of this hearsay only. So you can ignore it if you wish.
Here People do not do real experiments. They tend to think electronics can replace electrical machines. Pray tell me which electric generator is small. I have not put magnetic shielding and that's the reason for my problems. Even a bicycle dynamo has magnetic shielding. I will need another six to 9 months of rest and recuperation to again do these experiments. Assuming that I have recovered and then continue to have the desire. Puny proof of concept devices will not work.
Let me take leave now. Thanks
Respectfully
Ramaswami
Hi Ramaswami ,
Is real sad hear about your health problems , myself suffer some of this problems last year when i conducted some tests in one of the devices i made . Not only me affected but all people in the building where i  run the device . I'm almost full recover , but yes several months to recover from , permanently Migraines, intestine problems, problems to walk and even tumor .  I able to measure high values of radiation (about 300µSv)
from this device and seems this radiation could not be blocked even by normal shielding like aluminum foil , high freq mesh , wood etc.
The important is that you should know that i able to recover my healthy by balance again the Electrolyte of body  with Pink Malaysian Salt .
I'm healthy again , and i stop work in that device in particular . Maybe you could give a try ;) even if you are a skeptic about this theme .
I see many many people play with fire, without know the real dangers beside in some type of experiments.  I just could figure out that you deal in your system with low freq coils Hz when you get sick , and when i refer to low freq i include even higher freq in range of kz caused by harmonics when coils collapsing because the secret is how strong you punch this coils.
You problem for sure is a problem of unbalanced ions in your body  . You could give a try to recover your condition .
About  innovo machine i wonder why no one ask the reason to the unity use a bank of batteries 36v 40A inside the machine , and when you sign the contract to buy the machine you must agree not open the device under 5 years . That machine after start working  capture static electricity that is used to recharge the batteries again ,  and that is very nice but need have the batteries to store what is collected or  ... in Supercaps ;)
Hope your health change fast .
Compliments
Nelson Rocha
memoryman
Did you ever calculate how little energy in electrostatic form can be collected? It's in the Wh range, not kWh.
Zeitmaschine
NRamaswami
I am grateful for the kind words and please pm me on the ion balancing method and I will check it.
Regarding what caused the health problem I think it is lack of magnetic shielding coupled with high intensity magnetic field conditions. Shielding was attempted and then avoided due to high heat it caused. We did not encounter any problem to others except me who remained near the tested devices. Highly intense magnetic field could be felt up to four to six feet away from the large  electromagnets and not shielding them caused the problems. We did not have any equipment nor do we think we had radiation problems. No problem to neighbours. Low frequency high intensity magnetic field conditions caused problems. I have not maintained records of various experiments I conducted. Neither in paper nor in computer. But I remember that AC had problems of merging of voltage unless many conditions are met and pulsed dc had problems of high current drawn at source at higher voltages which wires could not handle. But I have not desired to remember all those things that caused me problems of health and so I had forgotten the exact details.
No idea on how the innovo machine construction. I have heard from a source I trust thats real. Nothing more. I have no specific information.
Ramaswami
