Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
ayeaye
I think that citfta did a very important experiment, for the first time a permanent magnet device was measured. What the result will be, maybe nothing, just eroding a fixed ideas.
Floor, please understand, scales have some systematic error. Means measuring the same value several times may not increase precision. This systematic error is though mostly tied to the value, thus when measuring different values, the error can be considered to be random. Measuring the same force with several different scales, may  increase precision though, but the scales should then be preferably different types, so they don't have the same systematic error.
I said that in that case, the best may be to calculate the error of the greatest measured energy, and then consider that to be the error of the whole calculation. When this energy is significantly great. Like i think that citfta can safely consider the error of the energy of shifting the shield magnet, as the error of the final result of the calculation. That is likely the force of shifting multiplied by 100 mm in that case. This would be the error of the difference between the input and output energy. As this energy is the greatest and the most significant in his experiment. The other measured energies are all much smaller, and with a very high probability, their errors are not all to one direction.
Measuring that energy with fish scales though, would have a very great error. Such scales, as i asked from other people who have such scales, indeed have an error +/-1 ounce, thus like when it shows 5 ounces, it may also be 4 ounces or 6 ounces. Thus in that case of shifting the shield magnet, the measured force was 5 * 0.278 = 1.390 N, with the error +/-1 ounce, that is +/-0.278 N, that is the minimum and maximum values will be 1.112 N and 1.668 N. The energy of shifting will thus be 1.39 N * 100 mm = 139.0 mJ, with the minimum value 111.2 mJ, and the maximum value 166.8 mJ. The error of the difference between the input and output energies will then be 139.0 - 111.2 = +/-27.8 mJ, regardless of what the other measured energies will be.
ayeaye
Quote from: shylo on October 15, 2019, 04:13:24 AM
An end on view ,the field curves around and terminates at the middle of the thickness, not at the other pole.
Yes and this is a good thing, this makes it more to one direction.
How can i say it intuitively. The magnetic field is caused by electrons orbiting the nucleus of an atom. The force is between these orbiting electrons, like one may think that it is between two circles, though they are kind of clouds. But nevertheless, this makes the force to be more in one direction, than in the Coulomb model. That is, for that reason the magnetic field differs from the poles being just a point charges, in that case it were symmetric, a spherical field is symmetric. As it is not entirely symmetric in that way, one could assume that it is asymmetric. And in theory an asymmetric field should be able to do continuous work.
citfta
Ayeaye,
Would you PLEASE do some basic research before posting.  You have made many posts in this and the other threads about magnetic interactions that show you have not taken the time to do any real research.  I don't mean setting up a big lab with a lot of expensive equipment.  I mean that you should at least take the time to read all of a thread before posting.  It is just not polite to read a couple of posts and then jump in with comments.
I say this because of some comments you have made in your posts.  If you had read ALL of the posts in this and the other threads you would have seen the other videos I have posted.  If you had seen them you would have seen how I mounted the aluminum rails so they could move freely. And you would have seen how many bearings were on each rail.,
If you had actually read all of Norman't posts in his thread you would have seen references to what he is doing and would understand his picture he posted.
If you would take the time to actually get some magnets and work with them you would soon realize your idea of free energy from a magnet will probably not work.  My work and others seem to show that your sketch of magnetic forces does not seem to be supported by real world testing.
I mean no disrespect but hope you will realize that making comments about others without taking the time to really understand what they are doing is not a good way to build a relationship with them.
Respectfully,
Carroll
ayeaye
Quote from: citfta on October 18, 2019, 05:35:06 AM
No, i only watched your video with measurements, i have not watched your other videos.
Well, if you now did watch my video that i posted together with that drawing, then you did see that i did an experiment, that also showed overunity, that though couldn't overcome friction, and it was not completely independent of the hand movement. That is, something that everyone can try oneself, but not that a video only can show. But if you come up with that argument, you had to first see my video.
shylo
I watched your video, and the ones after that too.
There's no overunity there.
Just a circular V-gate.
The problem you had with the spot where the magnet wouldn't align,
Is where the field terminates.
artv
