Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
Floor
                             https://www.youtube.com/watch?v=zWld721Wk-Q
                         floor
norman6538
Floor, the youtube is so out of character that I suspect that you got hacked.
I have recovered a bit but my wife was back in the hospital for 5 days and now things have settled down enough to get a few hours back at the bench. So if that keeps up I should have some test results in a few days. I am waiting for the shoe glue to dry because some times hot glue to metal lets go but shoe glue really holds well. I'm trying to get power from repelling magnets by extracting a piece of metal between them releasing the repel work out. Now its up to the measurements...
Norman
citfta
Hi Norman,
I am not familiar with shoe glue but I have found two glues that seem to work well for my projects.  The first is Locktite GO 2.  It is heat resistant and waterproof and very strong.  I have not been able to get anything apart I have glued with it.  Only use it if you are sure you don't want to ever take apart again whatever you glue.  I have destroyed several magnets I glued with it when I tried to take them apart to reuse them.
The second glue I use is Goop.  It makes a pretty strong glue joint for holding things in place.  It is hard to pull straight apart but a strong twisting action will allow it to come apart.  Also the residue is like rubber cement and can be rubbed off whatever it is on.  It also stays somewhat pliable after drying so is good for projects where you might need a little flexibility.
Glad to hear you are on the mend.  Hope your wife is soon back to normal also.
Take care,
Carroll
ayeaye
The shoe glue is just rubber cement. There are many such glues, but they are basically all the same, it's rubber in a solvent. When the solvent dries, what is left is rubber. It is strong enough for almost all purposes. Because it's rubber, it can also be later removed, but removing it is not that simple.
Floor
@Norman6538
Keep getting stronger.
Stay chill.
   floor
