Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
Floor
@ all readers
Electronics was an elective subject  I took in school.  Back then they still began such courses with teaching about static electric charge interactions (It's been a while). I don't think there is such a thing, at least not formally, as the "Coulomb model".  I didn't  Wiki Pedia it though.   With out looking it up, and while omitting the specifics.
The Coulomb is a unit of measurement.  1 Coulomb = a very very large number of electrons.
1 Coulomb of electrons moving past a given point  in a conductor, in 1 second of time = 1 Ampere of electrical current.
Without being goaded into making some kind of denial as to what that definition is,  nor
that electric charges of opposite polarities attract and so on, nor the concept that from a THEORETICAL POINT SOURCE,  Coulomb force diminishes with distance as the inverse of the square of that distance  I just have to say.
Look at this PDF files if you wish...
     Note that these are parts of a work in progress and please do not redistribute them at this time.
ayeaye
Quote from: Floor on March 21, 2020, 01:17:39 PM
Yes. Read the Wikipedia article about Charles-Augustin de Coulomb  https://en.wikipedia.org/wiki/Charles-Augustin_de_Coulomb
QuoteHe discovered first an inverse relationship of the force between electric charges and the square of its distance and then the same relationship between magnetic poles. Later these relationships were named after him as Coulomb's law.
This about the magnetic poles is the Coulomb model for magnets. Later it was found that the magnetic poles don't always have exactly such relationship between the force and distance (Gauss equation). That provides a perfectly spherical field. Nevertheless, this model has been used also after that for magnets, in the simplified cases.
The importance of that model for overunity, is that there cannot be overunity in the magnets setup that works exactly by the Coulomb model. Because no matter how many poles there are or how they move, exiting a spherical field by whatever path from a certain point, requires exactly the same energy that was created by entering the field up to that point by whatever path. And this is  true for all interacting pairs of poles separately, thus there also cannot be overunity in the setup as a whole, no matter how magnets move or rotate.
Thus, for there to be overunity, there have to be differences in the setup from the Coulomb model for magnets. Finding these differences enables to find how and in what direction they may provide overunity, and thus make a setup that has overunity as a whole.
PS Floor, i'm sorry but i cannot read your pdf files, as on my computer they appear as some kind of bin files, and there is no way to open them in any way.
citfta
Thanks Floor for your clearly presented documents.  The illustrations are clear and very helpful.  I appreciate the effort it takes to create documents that nicely presented.
Carroll
gyulasun
Quote from: ayeaye on March 21, 2020, 01:54:53 PM
For some unknown reason, the Admin of this forum has changed something in the software settings and the attachments can be downloaded only by Chrome or Explorer (these two are the ones I tested)  but when someone has Firefox browser for instance, the attachments download without any file extension and with a much different file name, as you mentioned them as some kind of bin files. The number of the bytes (file size) remain unchanged, only the name changes and the original file extension is cut.
You can do the followings:
Simply copy the original file name and Rename your downloaded bin_file_looking file to the original one, then you can open it as a normal pdf file.
Or use one of the above mentioned two web browsers, both downloaded the two pdf files correctly for me.
This happens not only with pdf but picture files too, but using one of the two methods mentioned above, they can be downloaded.
Gyula
