TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
Floor
Floor
I'll do more tests before I build the fixtures.
Floor
3 minute video.
https://www.dailymotion.com/video/x80z9wr
If the track can be long enough,
after extraction, insertion and repositioning to the start position
of the output magnet (even at considerable energy expenditure)
this is still O.U..
After the video, click here
https://overunity.com/16987/td-replications/msg556715/#msg556715
to jump back a few pages, to the start of this particular design / investigation.
    floor
Floor
observation...
One reason and probably the main reason, I was having
sticky spots in the "track" array was unevenly matched
track array magnet strengths.
While I was making this last video,
https://www.dailymotion.com/video/x80z9wr   (3 minutes long)
I was expecting a sticky spot if / when the output magnet is almost touching
the output magnet array.
The lack of a sticky spot in the output magnet action caught me off guard /
surprised me.
The only sticky spot, occurred when the output magnet caught
on the edge of one of the track array magnets.
So, once again, inconsistency in magnet strengths has caused me some
confusion in determining results.  Ha.
   floor
Floor
Observations...
Here are some of the common characteristics in the magnet interactions in
these designs (with some exceptions).
1.
Interactions, the motions,  input and output, are limited to specific
directions in relationship to the line of the magnet,  magnetic polar axis.
These directions of motion are always in some increment of 90 degrees.
2. A near to balance between magnetic attractions and repulsions is arrived
at / created, in one or more planes.
3. Sliding / rolling track systems prevent motions which would otherwise be
caused by some of the magnetic forces present, while also facilitating motions
along other lines.
4.  Changes in magnet positions occur, one at a time.  Each occurrence of a magnet
motion, starts, completes, then ends, before a next motion occurs.
5. There is a repeating cycle.
6.  There are 3 input actions for every 1 output action.
7. There is a point in the cycle in which a relaxation of / near disappearance of forces
occurs.
  best wishes
     floor
