OVERUNITY AT LAST !
Started by magnetman12003, December 08, 2016, 04:29:47 PM
Quote from: magnetman12003 on December 09, 2016, 04:27:32 AM
I only have one 12 volt 1.2 amp battery connected to the circuit.  The other batteries you see there are spares and are not used. I should have removed them to make a clean setup.
Do not confuse "Amp" with "Amp-hour" (A-h). Your battery is capable of producing a current far higher than "1.2 amp" when driving a low-impedance load. "1.2 Amp-hours" is a measure of the energy capacity of the battery. 1.2 Amp-hours at 12 volts is equivalent to a stored (deliverable hopefully) ENERGY of 12v x 1.2 amp-hr  x 60 min/hr x 60 sec/min = nearly 52 thousand Joules. I encourage you to "do the math" and to observe that the units properly cancel and result in units of Joules (Watt-seconds) in the answer. This is the figure you have got to beat somehow in your circuit's "output". To make it simple, the battery contains, when properly charged, about 52 thousand Joules of energy. You need to prove that your system can output more than that, before the battery runs down completely and your system stops running.
This energy can be delivered at a low power level over a long time, or at higher power levels for shorter times. Your video, unfortunately, does not show "OVERUNITY AT LAST!" but rather reveals once again how easy it is to be confused by pulsed circuits with high inductances, combined with less-than-adequate measurements and a lack of grounding in the basics of electricity and physics in general.
citfta
@ TK
Very glad to see you back.  You are of course completely correct in your observations.  The thing that caught my attention was the mention of overheating problems with the transistor.  I don't believe any circuit could be OU if it is wasting a lot of energy heating up a transistor.  Why people think they can invent an OU circuit or device without learning the basics is what I don't understand.
I am so tired of the old line they put out about not wanting to be confused by the "wrong" teachings in our school systems.  That is like saying I want to explore unknown parts of the world but don't confuse me by teaching me how to read a map.  We have to learn what is known before we have any chance at all of recognizing something that is unknown.
Edit: I see he has replaced the original video with another one.  My comments about the overheating transistor were about the original video.
magnetman12003
Quote from: magnetman12003 on December 08, 2016, 04:29:47 PM
Check it out on the You Tube.  All explained in my comments. I am willing to share the circuit with those interested but first I have to find someone that's good in CAD drawings to update my older drawing.
https://www.youtube.com/watch?feature=em-upload_owner&v=CzOo6aVEOzo&app=desktop
The bottom line is the circuit draws 6.7 watts and it is powering two 7 watt lamps to full intensity  ALL THE TIME IN BOTH CASES.       Any reference to a transistor overheating is found in one of my other projects completely unrelated to this one.
ayeaye
Quote from: magnetman12003 on December 09, 2016, 12:48:10 PM
And what is extraordinary in that? Two 7 watt lamps can well burn with a half brightness, with 6.7 watts. It is very difficult to measure brightness of lamps, no one also knows the sensitivity of your camera, cameras automatically adjust sensitivity. Lamps are also otherwise very bad as a load, in addition they are also non-linear. Better use resistors.
Measure input and output power with oscilloscope. I know it is much more difficult, but this is extremely important. A completely unavoidable and necessary evil. If you use computer microphone input as an oscilloscope, it has ac coupling, your multimeter may show the dc component.
As i said i cannot read youtube comments, i think some others who are not registered there, also cannot.
Use gschem for circuit diagrams, free and easy to use, install geda.
Turbo
I have some LED's here i think they are overunity leds... can i send you a pic so you can see the brightness and confirm that they are ?
