Reality and it's transmission of force and energy
Started by jbignes5, December 24, 2016, 10:31:45 AM
jbignes5
 In all of my investigations into what energy is and how it moves, I have had one nagging question of what is responsible for the action we see.
My oldest Theory is that there is something, a conductor to allow "Spooky" action at a distance and everything we see around us.
This is it:
A liquid crystal
Original reference that is zoomable so you can see the direction of the sub particles.
https://en.wikipedia.org/wiki/Sierpinski_triangle#/media/File:Sierpinski_pyramid.png
It is very important for for you to understand what makes the polarity difference. If you stack one of each color base to base not only does the polarity match but you can start to see how they would operate in a liquid way capable of moving about. Red is a charge carrier and blue is the vehicle in a bipolar example. The red one is full of space(charge level or motivator) and the blue one is full of surface(Directional).
The middle section shows the bipolar version unified or conductor or neutral conductor.
jbignes5
 What is my proof:
Lets look at the liquid crystal we know today in electronics:
https://www.youtube.com/watch?v=rX4nBZauFeY
https://www.youtube.com/watch?v=GnBhyg6wSXw
Biology and liquid crystals:
https://www.youtube.com/watch?v=pGz6ulKerPw
This is a longer version of what liquid crystals are and how they can be manipulated by us:
https://www.youtube.com/watch?v=ORKy169zz6g
Mostly these liquid crystals we use today are a gross matter. The fundamental action is what the red and blue structures above in the first post. They are polar and can become bipolar into a force arrangement. With a vehicle and charge carrier.
jbignes5
 What makes up these thin long rods is the red and blue pyramids. Lines of these form via the base area being focused to the tip area and the areas of the planes of the slopes. Long chains connect matter allowing conduction or induction, based on the condensing of where the charges are placed on either side of the long chains.
Red -> charge carrier or motivator
Blue -> conductor or vehicle
Blue+Red -> neutral -> Space
These components are all highly piezo electric in nature. With charges being a constant impact within the charge carrier's structure. What makes the charges charges is merely a density issue. Charges are very small in comparison to the charge structure and highly mobile via the slopes of the planes of the tip focal point. They are self guiding via this mechanism and through the piezo electric nature bump into the bases of the charge carrier.
They are fractal based and I doubt we would be able to work through the intricate sizes down to the smallest scales. I highly doubt we could find the smallest aspects of these. But do we really need to go that far? No.
jbignes5
 So what is a plasma then in this observation. Nothing other then the attraction and condensing of the very basic structure I sited above. The particles are not only piezo electric they respond to electrical stimulation through the network of the medium itself. Which is nothing more then a low potential of plasma with less charge. Ie the particles spanning space itself.
I'm still working on this so it is not fully complete.
jbignes5
Quote from: jbignes5 on December 24, 2016, 01:20:21 PM
As a side note here is when we can see inside of a motor and the combustion process. Remind you of something?
https://www.youtube.com/watch?v=-XkL9JjHY8Q
This shows you when we can't see the process how we can go way out of the path of truth. Thats plasma being freed from the matter of gas. After it condenses it expands back out causing the pressure forcing the piston.
Another proof of this is the pap-engine.
Watch it in slow mo and pause it from time to time. You will see the spark go off then plasma gets released from the gas. Once that discharges the gas itself is fried by the amplification of the spark through the plasma. What is left is fried matter as the exhaust.
The Paul Pantone system is just a system to take advantage of this process:
https://youtu.be/d5YsK3bwzPM
It can be argued that plasma is the force itself and not the matter binding plasma.
We have had the answers all along. But the powers that be don't want their power subjugated. They were the reason this guy went to jail because he had the answers already. Not for any other reason did he go to jail.
Now lets think about the Meyer's system. He had it as well. Plasma rich source of energy in the water. Free it and we can generate from it easily in many ways cleanly and cheaply. Hopefully this time now that it is in the open it can't be stopped.
