GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
citfta
Now, please remember, these 1-3 mini-pulleys, with AC generators attached, run practically torque free
It doesn't matter how many times you keep repeating this, it still IS NOT TRUE!
You just can't seem to understand that it takes TORQUE to turn a generator.  And motors do not run on a spark of electricity.  They run on a continuous supply of current.  That current coming from the generators will load the generators requiring TORQUE to turn them.  Your idea has been tried many many times with failures each time.  It DOES NOT WORK!
If Christ is coming back in two years as you claim then why bother trying to make free energy?  If He comes back then, we won't need any energy.
that_prophet
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year peace treaty with Israel MUST START before the Door closes on 2019.04 - http://doorschristmustpassthrough.yolasite.com/. I believe that we were given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half  as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel offspring with women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood.
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started. Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
   This technology is so super simple, that it is proof of there being a battle going on against good + evil, how else could this dirt simple pre-school learned, pulley technology not have been found. You only have to pay the energy to rotate a large 100 cm circumference pulley one single revolution, (a mere spark of current) + you can get a return of 100-300 cycles of AC electricity. I say hundreds of cycles of AC electricity, as you can add as many of the 1 cm circumference pulleys as you want, all running past the same 100 cm of belt that comes off of of your DC drive motor + 100 cm circumference. Thereby multiplying the # of 100 time multipliers as you want to invest in.
Please remember, these mini-pulleys with AC generators attached, run free of practically free of any torque, as they are just free running motors/generators winding up massive voltage,(which is exactly what you want) where they only need to generate one small spark of DC current, in order to have this mechanism a self powering mechanism..
The making of this simple GEM =(Geometric Electricity Multiplication) free energy technology
You start with one large 100 cm circumference pulley,
+ you attach one DC motor to it, + this is your drive motor,
can be any voltage, as long as the same as your AC generators
Then you get 1-3 mini-pulleys, each of 1 cm circumferences,
+ then you attach AC generators to them,
Now you connect these generators to 1-3 full wave bridge rectifiers,
To convert your AC output back into the DC of your input drive motor,
Then you run wires from the DC output of your full wave bridge rectifiers,
+ run them back into the input leads of your one single DC drive motor,
Now if you  only start to rotate your large 100 cm pulley, only a quarter turn,
This will generate enough power to not only start your DC drive motor working,
But it should be able to keep your DC drive motor running perpetually,
It should be able perpetually keep the system running because of pre-school pulley technology,
You see that the 25 cm of belt that you get from only a ¼ circumference of large pulley,
Is more than enough belt to give you 25-75 cycles of AC electricity,
By passing this 25 cm of belt by your 1-3 mini-pulleys of only 1 cm circumferences each
So each of these 1-3 mini-pulleys get to rotate 25 times each,
That's 1 to 3 X 25 = 25 to 75 cycles of AC electricity,
Now try and tell me that you cannot get the one spark of DC current,
Out of these 25-75 cycles of AC current
Remember that these 1-3 mini-pulleys are running free of most all torque,
As the only resistance these 1-3 generators have, (other than viscosity of lubricant)
Is the resistance of the power being generated by them,
Which is P=I V, which is "P"ower is equal to "I"-current multiplied by "V"oltage,
+ remember that no matter how high of a "V"oltage that you are winding up,
You do not need very much "I"current, you only need one short bit of current, (practically zero)
+ remember zero times any number is still equal to zero = (law of mathematics)
So,,, even massive "V"oltage times practically zero "I"-current,
Still equals practically zero Power = which take practically zero torque,
= these mini-pulleys are running practically free
because torque comes from generating power, and P=IV, where "I"-current  is equal to practically 0
(here is a picture that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1-3 not 4)
Please be assured, that all governments will not be long passing laws, stating that all polluting equipment + vehicles MUST  soon switch to this pollution free way of operating all of our gas guzzling vehicles + equipment as fast as possible. Just think about how much free money this world will seem to have now, not having to add the cost of gasoline into their products. I don't just mean for the cost of electricity, to heat, light + build your product, but the cost of shipping, everything from the materials to build it, but the cost of transportation of your workers, to and from the worksite.
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,,
Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6 + 9 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies the bird, + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that fund terrorist. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, that would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
FREE ENERGY from the description of how a running UFO motor looks in the Holy Bible
I have a most generous gift, http://free-energy.yolasite.com/ that I believe came from the God of the Holy Bible. I believe this because when I asked Him for a way to help the soon coming Tribulation Saints. I was shown a Vision of a 10 speed driving uphill in tenth gear, and then downhill in first gear, where the pedals were rotating like crazy. I then converted this into one large 100 cm circumference dive pulley, (powered by a DC motor) + this freely turning 10 of the 1 cm circumference pulleys, with AC motors/generators attached. This dirt simple GEM free energy mechanism only has an input one small bit of DC current, (only one spark) + has an output of 10X100=1000 cycles of AC electricity,
NOW THAT'S A FREE ENERGY MULTIPLIER
   The thing is, that there is the most powerful spiritual warfare going on about this simple free energy technology, and evil forces will immediately start confronting you as soon as you start looking into this. I can be sure that evil forces will whisper in your ear, many ways that this cannot possibly work. For why should evil spirits want us to be able to stop buying oil, from nations that in one way or another tend to promote terrorist, and their careless destructive ways. I believe that God gave me this technology back in the early 2000's when He first gave me a Vision of a 10 speed bicycle going uphill in 10th gear, and then back downhill in 1stgear. This is very significant where AC electricity is concerned, where you may need massive voltage, to crank over the pedals on the way up, but it costs way less current, as the motor runs for only a few rotation. Then when you run the bicycle down the hill in 1st gear, you would be winding over your AC generators massive amounts of time. Please remember that AC electricity is generate through rotations of a coil of wire through a magnetic field, and the more rotations means more AC electricity.
   I will guarantee that massive evil spirits will try and give you many reasons that this could never work, trying to discourage the idea of this even working. I can guarantee that Satan and all of his evil spirits will find many of ways for this not to work, whispering to you that only fools would believe in this stupid technology. It might take massive voltage to crank over your large 100 cm circumference pulley, but it takes practically zero current to rotate the DC motor the one single time. This means that there is practically zero torque needed to turn these AC generators over, as torque is only caused when you are generating power. + Since power is defined as P=IV, where "P"ower is equal to "I"-current times "V"oltage, and since you current is practically zero, and we all know that zero times anything, even massive voltage, would still be equal to zero,,, or practically zero.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
   This is so super simple, that I MUST state, that I happen to be ashamed of being human, and so gullible, that I believed these ridiculous lies about torque being a problem. These are free running electric motors/generators, and the ease that these can be rotated is going against only the viscosity of the lubricant, or practically zero. Think of it this way, the only resistance from rotation is caused from the power being generated by the motor/generator, which is only one single jolt or spark –(the minuscule amount of current that the DC drive motor takes to do one single rotation), which is practically zero current, and mostly all voltage, which is the electrical pressure to crank over this large pulley.
Especially since we have 1000 rotations to divide it by, so the torque is even, the minuscule amount that it takes to produce one spark of current, what it takes to rotate only the one time, and then divide this small amount by 1000. This is far less than nothing, so these 10 generators should be free running.(torque is only cause when you are producing power, and even massive Voltage multiplied by practically zero current, <one spark>, is still equal to practically zero. Because any # multiplied by practically zero, always equals practically zero.
Having the first Door closing by 2019.04, http://my2020vision.yolasite.com/ we have less that 20 months now, before the pre-Trib Rapture + signing of the infamous 7 year peace treaty with Israel, ushering in the anti-christ + the "Great Tribulation" + then Christ will set His Feet on the Mount of Olives, to fulfill the second part/Door of this prophecy, when He Comes again to this earth. This coming cannot be the arrival that no one knows, because the Tribulation Saints will not only know when this arrival will be, but they will be counting down the days until.
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/
http://rapturequestion.yolasite.com/
http://aliensandghosts.yolasite.com/
http://askthatprophet.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://possibletimingfortribulation.yolasite.com/
http://overunity.com/17091/gemgeometrical-electricity-multiplication/
that_prophet
Quote from: citfta on May 31, 2017, 08:24:48 AM
http://free-energy.yolasite.com/ = (PLEASE GO HERE, to see more about this GEM of free energy)
How much torque does it take to rotate a free running motor/generator = practically none
These motors/generators are pretty much free running
As for all of their 100 – 300 rotations, they only have to generate the small amount of current,
that it takes to rotate your drive motor one single time,,, only one small spark of current,
and this is divided by 100 – 300 rotations of you AC generatots
It only takes torque when you are generating power
+ the 100 – 300 rotations of these 1 – 3 generators only have to generate a spark of current
I say one spark because if your motor is running a 60 times per second, which is not a very fast motors
Then one rotation is only 1/60th of a second in duration =(a mere spark to me)
This is all that your 1-3 generators have to generate,,,,,,,,,,,,,
To rotate you DC drive motor to move one single rotation
Where has it been tried before ?
How can you go wrong when you only have to generate the single bit of current,
that your drive motor takes to rotate one single time,
+ you get 100 – 300 rotations of AC electricity to do it,
Seems easy enough to me.
You are using the dirt simple laws of pulley mechanics to multiply rotations,
+ since AC electricity is generated by simple rotations
You are using the dirt simple laws of pulley mechanics, to multiply your AC electricity
IT IS TRULLY THAT SIMPLE..................................
NOW, can you believe how gullible that listening to these evil spirits has made you,
I hope this not only clues you in, to the powerful evil forces out there,
But it convinces you of your need to seek God, + take Jesus into your heart,
Thereby becoming Born-Again, and maybe even start looking for His Second Coming,
+ get to use His "Blessed Hope" + get to leave this earth in the Rapture,
Before the soon coming 7 years of this false treaty,
where the second half will be the "Great Tribulation"
+ SATAN HAS CLOUDED YOUR MIND, SO THAT YOU CANNOT UNDERSTAND HOW SIMPLE THIS IS
http://decimationofthisevolutionfairytale.yolasite.com/
It will be less than 20 months now,,,, before 2019.04 the Door will close,
One of the Doors that we are allowed to know
Mathew 24:33 = "know that it is near, even at the doors"
Doors are plural because of His two Comings = Rapture + Glorious Appearing
that_prophet
Do you want to hear how super simple this technology is,
You only pay to crank over one 100 cm circumference pulley,
Then you use the moving 100 cm of moving belt off this large pulley,
+  run it past 10 mini-pulleys of only one centimeter circumferences,
All that you have to do is add AC generators to these 10 mini-pulleys,
Giving you a free return of 100 cycles of AC electricity.
And don't you believe that torque is a problem,
You have 10 X 100 = 1000 cycles of AC electricity,
To make up the one spark of DC current that you need,
That this DC drive motor needs to be cranked over the one time,
Giving you the 100 cm of moving belt = off 100 cm circumference,
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS
+ how powerful this spiritual warfare is,
to be able to hide this super simple AC multiplier from us gullible humans...............
Quote from: webby1 on June 01, 2017, 01:43:21 PM
No one is saying that you can not.Right here you have said "practically zero" NOT ZERO.I moved this here so that it is not missed up there,,
You are NOT multiplying a number by ZERO,, so it IS something.  Practically nothing is still something.
No it is not.
"Practically" is what is known as a weasel word.
https://www.merriam-webster.com/dictionary/weasel%20word
Take some classes in advertising,, you will learn better phrases to try and fool everyone with your delusion.
Low-Q
@that_prophet
Build your machine. Theories doesn't make things work, or make sense, untill you have proven that the experiment corresponds to the theory.
If the experimental outcome corresponds to the theory, the theory is correct, but if the theory doesn't correspond to the experimental outcome, you must discard the theory - not the experimental outcome.
Good luck with your build, and please post your experiment here when you're done.
Br. Vidar
