GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Here is GEM =a simple free energy technology for the Tribulation Saints
((( NEWS of this ancient technology will change the world )))
http://free-energy.yolasite.com/
I have the MOST IMPORTANT NEWS
To share with you + this whole world. Unfortunately this NEWS has two sides to it, one side is the best, most awesome God Given Gift, and the other side is the most horribly scary kind of news. THIS BEST NEWS is that FREE ENERGY is easy to produced, and can + will even lead to anti-gravity. Yes, that's right, this GEM=(Geometrical Electricity Multiplication) technology will eventually lead us to a way of defeating + repelling gravity. PROOF = this tech is found in our Holy Bible, (Ezekiel 1:16- where it is describing the appearance of a working UFO motor)
This FREE ENERGY technology is so simple to explain + build + use, you will wonder how it has not been discovered earlier=(evil forces were + are hiding this free energy technology). With this super simple technology, you only have to put one spark of DC electricity into this GEM=(Geometrical Electricity Multiplier) mechanism, to get a return of 100's or even 1000's of units/cycles of AC electricity. That is because you only need to rotate your DC drive motor once,(costing only one spark of DC current) with a 100cm circumference pulley attached. This large pulley is attached to a long belt, strap, rope, or even string,(in a pinch) strapped around your 100cm pulley + 10 mini-pulleys with only 1cm circumferences, + each mini-pulley has an AC generator attached to it. This GEM of a mechanism runs by converting the 10 X100 = 1000 units/cycles of AC electricity = duel sparks, into much more than the one single spark of DC electricity that you need to power your drive motor, by using full wave bridge rectifiers. (one for each of the AC generators)
This free energy technology works by only having to put one spark of DC electricity in, which can return you 1000's of spark cycles, or units of AC electricity out. It's truly that simple, you are seemingly breaking the laws of thermodynamics, by using many small pulleys to multiply your total # of rotations, which you can easily convert into AC electricity. These AC generators run practically free of any torque, as you only need to produce one spark of DC current, (practically zero current) + torque is caused by producing power, which is P=IV, or Amps=current multiplied by Voltage, and massive voltage times practically zero current, still equals practically zero power=torque. Then by using full wave bridge rectifiers, you can also easily convert your AC electricity into a lot more than the one spark of DC current, that you need to keep this GEM of a free energy mechanism running = producing a lot more than is needed to be self powering.
http://beliefstoliveby.yolasite.com/
This technology is in the Holy Bible = in Ezekiel 1:16 where he is describing what a UFO motor looks like while it's running so this technology will eventually lead us to anti-gravity as well as not only speeds approaching the speed of light but also the ability to do 1000 kph vectoring
I have already had one person confirm that this GEM technology does indeed work, as he said that he built three different versions of this free energy technology, that do indeed work. He was worried about the rumors that anyone who actually built a working free energy mechanism was soon after found dead. So, because he feared for his life, as well as the lives of his family, he asked me to not give out his name, or the fact that he had built three working versions of this GEM, free energy technology.
Dog-One
Quote from: that_prophet on January 18, 2017, 05:13:14 PM
Why even mention this person then, since it is pointless asking you to put us in contact with him?
If you were smart, you would at least get some pictures of his work and post them here.
To each their own I reckon.
that_prophet
Sorry, but I promised this guy that I would not gidve out his name, as he was worried about the rumors about the people that had built free energy mechanisms soon would end up dead. I believe that this is so simple, that it can be built by most people, with even half of a mechanical minded attitude. You only need to attach a large (100cm circumference) pulley to your DC motor, and at least one mini-pulley (1cm circumference) to an AC generator, and then connect them together with a belt, strap, rope or string. Then you put your AC generator output into your full wave bridge rectifier,(4 diodes) and connect the DC output to your DC drive motor. If you have it all connected right, you should be able to start this mechanism running by giving he large pulley a slight turn by hand. This motor + these generators would need to be the same voltage
Quote from: Dog-One on January 20, 2017, 07:56:21 AM
SkyWatcher123
Hi all, Hi that_prophet, the stationary bicycle generator is coming along.
Have the main structure built, need to get some parts for mounting the bike and then a long v-belt.
The bicycle has a 28" wheel, so i guess that makes the rim around 26.5 inches in diameter.
Not sure if that is a large enough diameter to see effects.
The main intention is to use it for exercise, fun and charging 12 volt batteries for powering my efficient lights.
The secondary intention, is to hook up a motor by chain, to the pedal sprockets and test out what that_prophet has been sharing with an amazing determination.
peace love light
that_prophet
This is really very simple technology, as it use the circumference change in a large pulley=(100 cm circumference), + using the belt off it's one rotation,(100 cm of belt) to multiply the # of rotations of a small pulley,(1 cm circumference) + thereby multiplying your AC electricity, by adding AC generators to your small pulley. Turning one rotation of a DC motor into 100 rotations of the small pulley + getting an output of 100 cycles of AC electricity. (the small pulleys do not take any torque to rotate, as they are just winding up massive voltage, as it only needs to generate one spark,(practically zero) of current)= to drive your input DC motor.
Quote from: SkyWatcher123 on January 20, 2017, 09:07:12 PM
peace love light
