GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
SkyWatcher123
Hi all, Hi that_prophet, well they may be trying to whisper in my ear, but i am using discernment and i will never say something does not work, that is why i am building this, to try and see for myself.
And yes, i agree, there are many mansions in the one creators kingdom and each of us, as individuated expressions of this one source creator, will dwell in the mansion (frequency dimension) that we resonate with.
I choose the service to others mansion, with love and kindness.
I have to go back to auto parts store today and get an 88" v-belt instead, my measurement method of the pulleys was not right, you have to tape the string used for measuring, around the bicycle rim edge and small pulley edge, as i originally, in error, placed the string in the wheel rim well and pulley well.
Then you tape the string to the floor and measure the belt length one needs.
peace love light :)
SkyWatcher123
Hi all, i have the proper v-belt installed and it runs nice and smooth with leg pedal power.
Next step, make electrical connections to alternator, i need a bolt to mount negative lead at alternator housing, then volt meter and 12 volt battery to charge.
Here's a pic of it ready to go.
peace love light
massive
good for you .    Im sure theres alot of people watching who wont post but they want you to do the build .
what model alternator or car did this originate from ?
I cant identify by the size of the fan
Paul-R
Shouldn't you have several alternators in the loop? Or do they come later? I'm wondering if there will be room unless you get some of those small 12vdc motors that also run as generators.
that_prophet
yes, great work...
and you should be able to add 1 or 2 of the alternators,
(without too much trouble... says the guy who is all theory... lol)
thereby double + even tripling your output,
and these altenators should run freely,
at least until you start drawing power off them
+ put it through full wave bridge rectifiers,(4 diodes)
if you are trying to eventually have this a self powering mechanism
and if you use a DC drive motor to run your pedal axle,
you should be able to multiply your AC power
by using pulley mechanics to multiply your # of rotations
+ multiplying rotations can be turned into AC electricity
by adding AC motors, or altenators, to your small wheels/pulleys
Quote from: Paul-R on January 30, 2017, 10:45:09 AM
