GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
pomodoro
Profet,one good thing about having your nonsense here is that it represents the most childish attribute of many on here.You have a condition where your great belief in this invention clouds all judgment and you fight hard to be heard and believe.But because of your lack of basic science, you have no choice but to offer this simple childish invention, which is easily dismissed by the most infantile inventor. Now add a few formulas , computer simulators, jargon, oscillographs, and you can see how some more advanced inventors can start pulling the wool over the more senior inventors. So your posts have done much to my understanding of some others on here that seem to go on for years but never admit to having a major flaw in their theory, and like you have nothing to replicate successfully.So cheers for that dude.
that_prophet
   This technology is truly very simple, as it uses the circumference difference of one large pulley of 100 cm, and many,(10) small 1 cm circumference pulleys. By using multiple smaller pulleys we can multiply then total # of rotations, and by adding AC generators, we can multiply our AC cycles of electricity. It is as simple as that, you are using the use of multiple pulleys to multiply your total # of rotations, which can be turned into AC electricity, by simply adding AC generators to the many, 10 small pulleys with AC generators attached.
   You are taking the 100 cm of belt that you get from the one rotation of a 100 cm circumference pulley, which costs only the slight amount of electricity that it takes to rotate a DC motor once.  This is called a GEM = Geometrical Electricity Multiplier because that is what it does, by using multiple # of small 1 cm circumference pulleys, with AC generators attached. So you only pay for one rotation of a large 100 cm circumference pulley, and get back a multiple of 100 rotations, for every 1 cm circumference pulley with an AC generator that you attach to the same belt. So, if you add ten small 1 cm circumference pulleys, then you would get a return of 1000 cycles of AC electricity, all for the cost of one rotation of your DC drive motor.
   This mechanism should run perpetually, with the 1000 cycles of AC, when run through bridge rectifiers, should easily be able to produce enough DC electricity to crank your DC motor over once. These 10 AC generators would be easy to rotate, as they are just being used to wind up massive voltage, and only need to have the slight amount of current that a DC motor takes to rotate one single time. Since torque is caused when you are generating power, and power is current times voltage, P=IV. Since we only need the smallest amount of current, practically zero, and zero times even massive amounts of voltage still equals practically zero. Thereby these small pulleys should rotate with practically zero torque, and they should be winding up massive voltage, which can be used to crank the DC motor over just the once.
     Just build this super simple GEM - AC electricity multiplying device, and watch it work. Once built, you should be able to start it running by simply giving the large pulley a slight rotation. These AC + DC motor/generators should run continuously, allowing you to tap electricity off of both your AC + DC generators/motors. If you find that this GEM free energy device does not have enough DC electricity to power your apparatus , then just add more 1 cm circumference pulleys with AC generators attached, to the same belt.
YOU ARE PAYING FOR 1 ROTATION + GETTING BACK 100,,, OR 1000,,, OR MORE
by simply using pulley mechanics, you can multiply your AC electricity cycles.
what I happen to be doing, is using simple pulley mechanics,
to change 1 rotation of a large 100 cm circumference pulley,
into 100 rotations of a 1 cm circumference pulley,
+ thereby multiplying the amount of AC electricity.
By simply adding a belt to connect these two pulleys,
and by simply adding 10 1 cm pulleys with AC generators,
   I originally added a battery into the system, to store the excess power, and added a warning to this mechanism, that left along, this battery charging device could explode + catch fire. I worried about this, because of it being able to continuously produce power, and overcharging the battery. I stated that you needed to have a cut off circuit, to prevent over charging.
that_prophet
This truly works guys + gals,,, I know that it sounds too simple to actually work. You are using simple pulley mechanics to multiply your total # of rotations, and by simply adding many small pulleys with AC generators attached, you could be using pulleys to greatly multiplying your AC electricity, instead of paying money to the terrorist for oil.
It is the billions of evil spirits that are screaming in your ears, "THIS WILL NEVER WORK" + "ONLY A FOOL WOULD TRY THIS". That is because they are desperately trying to hide this ancient UFO technology that can be found in the Bible = Ezekiel 1:16. They are + have been hiding this super grade school technology because they want us to keep buying oil,,, from countries that produce terrorist,,, to help create terrorism = what they like best
that_prophet
COME ON PEOPLE,,,,,,
PLEASE, shake off this spiritual dullness,
That is keeping us all blind to the simple logic,
That you MUST multiply your AC electricity,
When you only pay to rotate a large 100 cm circumference pulley once,
And you can, by adding a belt with ten small 1 cm circumference pulleys,
With AC generators attached to each small pulley,
Gain 1000 cycles of AC electricity
HOW CAN YOU NOT GET ONE SPARK OF DC CURRENT
Out of 1000 cycles of AC electricity
These AC generators run free of practically any torque,
Because torque is caused when creating power,
+ you only need the minuscule amount of current to rotate a motor once,
Which is practically zero,,, + P=IV
So practically zero current times even massive voltage still equals practically zero
Now I used a DC drive motor,
So you would need to have 10 full wave bridge rectifiers,(4 diodes),
To convert your AC output into your DC for your drive motor
that_prophet
Welcome to the END TIMES
(as of 2:27 – 2017, all who are born again + looking 4 His Coming, have less than 23 MONTHS LEFT TO LIVE, on this earth, before the Door shuts on this last generation=(51.6 solar years calculated from the 14+14+14 generations of linage of Jesus) + also used to accurately predict the rebirth of Israel, right down to the exact day.
Email: ask_that_prophet@yahoo.ca
http://askthatprophet.yolasite.com/
http://my2020vision.yolasite.com/
http://2020-vision.yolasite.com/
http://free-energy.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://possibletimingfortribulation.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://aliensandghosts.yolasite.com/
http://pre-trib-force.blogspot.ca/
http://doorschristmustpassthrough.yolasite.com/
http://hissalvation.yolasite.com/
http://godoflove.yolasite.com/
http://fire-starter.yolasite.com/
http://2020vision.yolasite.com/
http://one-christian-warrior.yolasite.com/
http://onechristianwarrior.yolasite.com/
http://ultimatejoysticks.yolasite.com/
http://ultimatevideogamecontrols.yolasite.com/
http://thegodofthebible.yolasite.com/
http://incaseofrapture.yolasite.com/
http://rapturequestion.yolasite.com/
http://whataboutisrael.yolasite.com/
http://myiqchallenge.yolasite.com/
http://evolutiondebate.yolasite.com/
http://biblefilescentral.yolasite.com/
http://whydoweinsultgod.yolasite.com/
http://jesus-christ.yolasite.com/
http://evotutionfairytale.yolasite.com/
http://howlogicchosechrist.yolasite.com/
http://hisonlyword.yolasite.com/
http://whybornagain.yolasite.com/
http://bibleteachings.yolasite.com/
