GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Re: GEM=(Geometrical Electricity Multiplication)
this uses the simplest of pulley technology to
only pay for one rotation of a 100 cm circumference pulley
which gives you 100 cycles of AC electricity back in return,
for every 1 cm circumference mini-pulley with an AC generator,
that you choose to attach to the same belt
if you choose 10 X 100 = 1000 rotations OR 1000 units/cycles of AC electricity
now, try and tell me that you cannot get this one spark of DC current,
out of these 1000  units of AC electricity, that you have generated with these multiple of rotations,
because this one spark of DC electricity is all that you need to power your DC drive motor,
+ rotate it only one single time, + by using simple pulley mechanics,
you can multiply into 1000's of rotations + 1000's of units/cycles of AC electricity.
Especially when the AC generators are just winding up massive voltage
Which works out as useful voltage pressure, to crank over your DC drive motor
Remember, you only need to generate,
one single spark of DC current, (practically zero)
To keep this running, by cranking this DC motor over once
And creating power costs you torque
P=IV + practically zero I-current times even massive Voltage
Is still equal to practically zero power = zero torque
It is as simple as using the 100 cm length of belt off of one rotation of a 100 cm circumference pulley,
to be multiplied into 100 rotations of a small 1 cm circumference pulley.
Through simple pulley mechanics, you are multiplying your AC electricity
you are trading off one rotation of a large 100 cm circumference pulley,
into 100 rotations of, as many of the 1 cm circumference pulleys that you choose to add to the belt.
So, if you added 10 of these mini-pulleys, you would get 10X100=1000 rotations,
which by simply adding AC generators, you could gain 1000 cycles of AC electricity.
That is, you are only putting in one small spark of DC electricity,
+ have the ability to extract 100 units of AC electricity, for every mini-pulley that you add,
That has an AC generator attached to it
HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY
– when you working with basic pulley technology,,, physical abilities
+ using this simple physical ability of trading one revolution for 1,000's of rotations
-especially when you are dealing with rotations when speaking of generating AC electricity
http://beliefstoliveby.yolasite.com/
sm0ky2
Can we extract energy out of his senseless spam?
He may not be "perpetual" but I bet he could keep
A device running for a very long time......
that_prophet
http://overunity.com/17091/gemgeometrical-electricity-multiplication/msg499717/#msg499717
this uses the simplest of pulley technology,
where you only pay for one rotation of a large 100 cm circumference pulley,
which gives you 100 cm of moving belt to work with,
+ if you attach an AC generator to a 1 cm circumference pulley,
that will give you 100 cycles of AC electricity back in return,
that you choose to attach to the same belt.
if you choose 10 - 10 X 100 = 1000 rotations OR 1000 units/cycles of AC electricity
THAT'S A RETURN OF 1000 UNITS/CYCLES OF AC ELECTRICITY
– FOR ONLY ONE SPARK OF DC CURRENT
(it only costs one spark of DC electricity to turn over your DC motor once)
out of these 1000  units/cycles of AC electricity,
that you have generated with these multiple of rotations of many small pulleys,
because this one spark of DC electricity is all that you need to generate,
to power your DC drive motor, + rotate it only one single time,
+ by using simple pulley mechanics, you can multiply into 1000's of rotations
Which can easily switched into 1000's of units/cycles of AC electricity.
Which works out as useful voltage pressure, to crank over your DC drive motor.
And creating power costs you torque, P=IV
It's as simple as using 100 cm length of belt, off one rotation of a 100 cm circumference pulley,
into 100 rotations of, as many of the 1 cm circumference pulleys that you add to the belt.
for every mini-pulley that you add, that has an AC generator attached to it
http://2020-vision.yolasite.com/
http://free-energy.yolasite.com/
that_prophet
Using pulley mechanics to multiply AC electricity
I was hoping that I could enrage many deceived people,
--- once they saw just how super simple this idea is, that these evil spirits are desperately hiding
--- --- but I have not yet been able to break this solid hold that they have on the masses
--- --- --- until now,,,
How can you not be multiplying AC electricity, when you pay for only one rotation of a DC motor,
--- with a 100 cm circumference pulley attached. (costing higher Voltage + 1 spark of current)
--- --- to crank it over once, gaining 100 cm of moving belt
--- --- --- and then getting back 1000's of units/cycles of AC electricity
--- --- --- --- by running your 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference
--- --- --- --- --- thereby multiplying your rotations to 10X100=1000
--- --- --- --- --- --- ( HOW CAN YOU GO WRONG )
(WHAT I CAN'T BELIEVE, IS HOW GREAT A HOLD THAT EVIL FORCES HAVE ON MAN)
--- to hide this super simple method of multiplying our AC electricity
--- --- from His ministers even
--- --- --- as I have tried to get 3 or more churches to patent this,,,
--- --- --- --- WITH NO TAKERS,,,
(CRAZY,,, considering that once this is discovered to be real, every government in this world)
(will pass laws, mandating that this tech is used + not oil burning engines,,, )
(which not only produce pollutants + cost money, but also funds terrorist)
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
---  All through what seemingly legally breaks the laws of thermodynamics
--- ---  by using simple pulley mechanics, that we learn in grade school
--- --- --- to actually multiply our AC electricity - (instead of paying for oil to generate it)
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add to belt)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
THAT'S ONE ROTATION OF A DC MOTOR BEING MULTIPLIED
--- INTO 100 ROTATIONS OF AN AC GENERATOR
It's as simple as using the laws of pulley mechanics to multiply our AC electricity, by paying for one rotation of a 100 cm circumference pulley, and gaining a return of 100 units/cycles of AC electricity.
WHY CAN YOU NOT SEE THE BASIC SIMPLICITY OF,
THIS USE OF PULLEYS TO MULTIPLY AC ELECTRICITY.
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your rotations = AC electricity
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing,
I mean those who had actually built working models
the Book that I put all of my faith in is the Word of God
+ if you want to see how the Holy Bible can prove itself God inspired
you should read a novel  called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
He did this by systematically going through fulfilled Bible Prophecies,
and showed how they were fulfilled right down to the exact day
+ Who else but God, could consistently predict the future
it was one of the rules with God, the one about how He gave a second chance to Israel
after 10 times the original duration
As in, when you take 10 times the original duration, of the prophecy about when Jesus would enter Jerusalem, you get a second chance for Israel. I don't know about you, but I happen to be quite the skeptic, and thought that maybe the reasons that these prophecies worked out so perfect, was that they were written or changed after they were fulfilled. But this one about Jesus entering Jerusalem on the exact day, + when you take 10 times the original duration, of the time between when it was prophesized + when it was fulfilled, you get may 14th 1948, when the nation of Israel was reborn. http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
http://decimationofthisevolutionfairytale.yolasite.com/
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
http://aliensandghosts.yolasite.com/
It was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
Written in the Holy Bible way back in Ezekiel's day
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming a part of God's Family
that_prophet
the DC motor takes only one spark of DC current to rotate one full time,
+ you get this "spark" of DC current by putting all of the AC units of electricity,
through a full wave bridge rectifier, (4 diodes)
this small amount of DC current =(1 spark),
rotates your DC motor once, with a 100 cm circumference pulley attached,
giving you 100 cm of moving belt to work with,
then if you run this 100 cm of belt past 1 to 10 mini-pulleys with AC generators attached,
you could get 100 to 1000 units of AC electricity,
THAT'S 1 SPARK OF DC, THROUGH PULLEY MECHANICS, GIVING YOU 1000 SPARKS  OF AC
Quote from: webby1 on February 11, 2017, 11:12:50 AM
It is still your turn.
How do you convert that single spark of AC electricity into the current that the DC motor needs?
