GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
Quote from: citfta on March 09, 2017, 06:48:48 AM
Well actually they do produce enough electricity to turn the motor.  IF the motor was not connected to the load.  What he has been told a thousand times and still doesn't understand is that with all those generators or alternators whatever he wants to call them connected to the large diameter the mechanical load will be so large the motor will stop no matter how much power is applied to the motor.
No, there is practically zero load on the AC generators, as they are only winding up massive voltage, as they only need to generate one spark of current. These AC generators only need to generate the small amount of current to rotate the DC drive motor one full time, and this is from 1000 revolutions of the AC generators. All of the 1000 revolutions from the 10 AC generators, only need to generate the small amount of current that it takes to rotate the DC drive motor one single time.
He refuses to understand the basic mechanical problem with his design.  He just does not understand that it takes real power to turn a generator when it is loaded.  He claims to be a genius but is unable to look up the simple basics of how a generator works.  He also doesn't understand how a motor works because he keeps referring to a spark of electricity to run his motor.  His very deep lack of knowledge has given him this delusion of an idea to produce electricity for free.
There is practically zero load on this system. Out of all 1000 revolutions of the AC generators, you only need to generate the minute amount of current that the DC motor needs to rotate one single time. Since torque is caused when power is generated, practically zero current times even massive voltage, still equals practically zero power = practically zero torque. These AC generators are just winding up massive voltage, which is exactly what you need to crank your DC motor over one time.
that_prophet
Quote from: ramset on March 09, 2017, 06:51:48 AM
So his name is Joe ??
@ Joe ,
Do they Let you talk on the phone there ?[
Yes, they do let me have a phone,,, lol
I can message you my phone # if you would like
I heard you were recovering from a very serious head trauma ?
I hope your recovery is going well.
I'm sending you a PM.
respectfully
Chet K
Thank you, and yes I have been recovering from a pretty severe closed head injury
this accident happened in 96, where I died twice, + then they even cut off my life support
it wiped out all of my short term memory, and 1 year of my long term.
I had to relearn everything, including how to speak
joe
ramset
Joe
quote
end quote
yes please do PM your number ,I will call you today
respectfully
Chet K
Thanks Grandma
that_prophet
Let me explain to you, just how simple minded that we have been brought down to, by the evil influences that Satan + his minions. My hope is, to aggravate as many people as possible, by showing them just how pre-school super simple this AC electricity multiplication technique truly is, and to get you to think about the power that evil forces must have over us, to be able to hide such dirt simple technology from us for so long.
If you have a 100 cm circumference pulley, (about 3-4 inch in diameter), driven by a DC motor + rotated only one single time, then it would only take the smallest amount of power. Yet it should be the simplest to see that as an output, this would surely return us a great multiplication of electrical power. Please, forget about this evil talk about torque problems, this one AC generator is a free running motor, with the only resistance that is felt by your AC generator is the viscosity of the bearing lubricant.
I can say this because you are only looking for the slightest amount of current, that it takes to rotate a DC motor once, barely a spark of current. Since torque is caused when generating power, and power is defined as voltage times current, and when your current is practically zero, your total power is practically zero. This is from the most basic mathematical rule, where zero times anything is still equal to zero, where zero is substituted with almost zero.
This truly does work,,,
That is why Satan + all of his evil dominion are working their hardest to keep this hidden
Just think of 10 free running electric motors,
They would rotate so easily that there would be little to no torque resistance,
These generators would simply be winding up massive voltage, (electrical pressure)
10 X 100 = 1000 rotations,(and by attaching free floating AC generators to each )
Which is exactly what you need, to be cranking over your large drive pulley the one time,
You only have to pay to rotate a 100 cm circumference pulley once,
Which costs merely one small bit of current,
+ through simple pulley mechanics of using 10 1 cm circumference pulleys,
with AC generators attached, you can gain 1000 cycles of AC electricity
This is a Gift from our Father in Heaven, to all mankind,
of the simplest form of free energy, using wheels within wheels-(Ezek 1:16)
by paying for the one rotation of a large 100 cm circumference pulley,
we can multiply rotations to 1000 by simply adding 10 1 cm circumference pulleys.
Now try + tell me that you cannot gain the power to rotate your drive motor one single time,
when you get an output of 1000 cycles of AC electricity to work with.
This works on the simple logic,,, of using the mechanics of simple pulley technology,
Where you only pay the amount of current to rotate a large 100 cm circumference pulley once,
Then through pulley mechanics, you are gaining a return of 1000's of cycles of AC electricity,
by adding 10 small one cm circumference pulleys with AC generators
This GEM free energy technology is as simple as multiplying rotations with varying size + # of pulleys. By only imputing the minute amount of electricity to rotate your DC drive motor one single time, (a mere flash of current, enough to crank the motor over once, just a spark).
Think of it as 10 motors running free, with only viscosity of the lubricant as resistance, especially with the new sealed or magnetic levitation technology.
10 free floating motors, not connected to any wires, so they are running free of any resistance, and would be just winding up massive voltage. Isn't that amazing, that massive voltage - or back pressure, is exactly what you need, to crank over your large pulley.
The mini-pulleys with AC generators will rotate 100 times, for every one that you add to the belt. So, if you only added 10 mini-pulleys, you would gain 10 X 100 = 1000 cycles of AC electricity.
This works on the simplest of pre-school pulley mechanics, to simply multiply your total # of rotations + by simply attaching AC generators, we can actually multiply AC electricity,,,
YES, USING DIFERENT SIZE + # OF PULLEYS TO ACTUALLY MULTIPLY YOUR POWER.
Yes, you can get away with seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to multiply your total # of rotations. This can be extremely significant, considering that AC electricity is created using rotations, and the more rotations equals the more AC electricity. If you use a DC motor to drive a 100 cm circumference pulley for one complete revolution, it only costs you one single spark of DC current, to give you 100 cm of moving belt.
.    Then all that you have to do is add an even larger belt, and run this length of 100 cm of moving belt past 1 – 10 mini-pulleys of 1 cm circumference with AC generators attached, you can gain 100-1000 units/cycles of AC electricity. YES,,, that's a return of 1000 units/cycles of AC electricity, all for only one single burst of DC current, the small amount that is required to rotate the motor one full rotation. It is truly that simple,,, and why hasn't anybody figured this super simple free energy technology before? It is because evil spirits are still, and have been trying their hardest to hide this technology from us humans.
.    How can you explain away this simple logic, of trading one rotation of a DC motor, for 1000 rotations of AC electricity. HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY,,, and you could be multiplying it by even greater factors, if you added a larger drive pulley, or more mini-pulleys of 1 cm circumference with AC generators on the same belt.
.    Satan + his fellow evil spirits have been pulling the wool over our eyes for too long. Please, join me in defying the evil rule on this earth, and not only help stop funding terrorists, but help us gain the advantages of anti-gravity.
-   I say this because I found this ancient technology in the Holly Bible = Ezekiel 1:16, where he is trying to describe what a running UFO motor looks like. "a wheel in the middle of a wheel", or as I pictured it,  a small wheel, running on the inside of a large wheel. But, since I did not have that ability to have a small wheel, running on the inside of a large wheel, I decided to go with a pulley, and have both wheels=pulleys run inside this larger belt.
.    Is not this sooooo simple, that it aggravates you to hear that this has been in the Holy Bible since the times of Ezekiel? I hope so, and that it proves to you that there is a most powerful spiritual warfare going on behind the scenes.
.    Is not spiritual
.    How can you not gain massive amounts of AC electricity, when you only pay for one rotation, and through simple pulley mechanics we can multiply our AC electricity.
I seriously hope that I have insulted your intelligence,
By showing you just how super simple this technology truly is,
Yet, it begs the question, why have we not discovered this simple technology long ago
f you attach a 100cm circumference pulley to a DC motor
it only takes one spark of DC current to rotate a DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley
then you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC generators attached
the greater amount of current you should be able to do work with
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
http://free-energy.yolasite.com/ = PUBLISHED 2001 OR 2002
(YET THERE IS SUCH A SPIRITUAL WARFARE GOING ON AGAINST IT)
((( evil spirits were hiding this tech = lies about torque being a problem )))
Now comes the bad+scary part of this awesome free energy technology discovery
You can easily see just how super simple this AC multiplication technology is
so why could not any one of the millions of above average intelligence have discovered this
long ago... as soon as AC electricity was discovered. Well this is hard positive proof
of there being powerful spiritual warfare going on all around us... + they were winning
I would say that these powerful evil forces were winning - if they could hide this from  us
I happen to be Born Again-(28-11-88) + want this super simple free energy technology known
long before the first Door closes for Christ's return in the clouds by or before 2019.04
http://doorschristmustpassthrough.yolasite.com/ + http://2020-vision.yolasite.com
This technology is in the Holy Bible = in Ezekiel 1:16
where he is describing what a UFO motor looks like while it's running
so this technology will eventually lead us to anti-gravity
as well as not only speeds approaching the speed of light
but also the ability to do 1000 kph vectoring
We are warned that no one knows the day nor hour... (Mat 24:36) but it says that we will know
when it is near... near to what? maybe the door.... as we can know when it's"even at the doors"
(Mat 24:33) + I heard that in the original Greek it was worded like a command "know that it is near"
With this technology the Tribulation Saints can keep warm in our cold Canadian winters
even off the power grid. (remember the heat + light of fires would easily give away
your position visually... as well as via satellites)
notice that Doors are plural - because He show up twice =
1) - Rapture = "caught up together with the in the clouds"-(I Thes 4:17)
2) - "Glorious Appearing" at end of Tribulation -(Titus  2:13)
( + there are less than 2 years left before the door shuts, the door Christ MUST come back through) . . .
ramset
Joe
It was good to speak today ,we will try to get you a simple simulator program for your computer.
hopefully you will have a good time experimenting on the computer ,I have a family member who suffered brain damage at birth and I can appreciate the challenges that you face .
The only thing I ask is you keep your comments here in this thread ,and I will help you anyway possible and I am certain others here will also help.
and please keep in mind here at this forum we work on FE devices ,we really don't get into politics religion or sports [yeah that can be a problem too]
maybe you could start a religious Blog and put a link at the bottom of your posts ?
with respect
Chet K
Thanks Grandma
