Magnet force shield
Started by Floor, January 21, 2017, 11:14:49 AM
Floor
@DeerSpotter
Some of these shielding methods worked, but  I did not find that any of
them resulted in over unity... neither do I now find any reasons why they
should have.
If you are a builder / do replications ?  you might consider
a replication of the experiment @
http://overunity.com/14311/work-from-2-magnets-19-output-2/msg388336/#msg388336
                   floor
Low-Q
Too bad it didn't worked out for you Floor. I honestly think the topic in the linked thread will lead to nothing but equilibrium too. There is allways something we don't consider that nature already knows.
However, I don't think you will give up chasing OU. Looking forward to see your future projects, even if I am a sceptic.
Vidar
Floor
Please find the following 2 attachments ......
"Magnet force shield 4.png    and    Magnet force shield 5.png"
Use the force neutralizing principles, illustrated by my drawings (in the previous parts of this topic),
in combination with a mechanical linkage (as described in the drawings attached below).
      These designs and devices are given into the public domain.
                        best wishes
                                  floor
norman6538
If I understand what you are doing correctly you are balancing springs and
magnets and what I have found in many cases is all is good till you take power
out and then the balance is disturbed and a price has to be paid to return to
that balance.
Butch Lafonte did a lot with balanced setups that nulled the sticky spot but
he never did any measurements. I have done measurements and they have
OU but not enough.
It easy to get a magnet to do free work but then the mechanism has to be
reset so it can repeat that work and that require work. If that work is
less than the work out then you can get OU. But I have achieved OU but not
enough to do the switching to repeat a cycle. Its been my experience that it
takes 200%-300% extra to achieve that switching/reset process.
Best of Luck,
I really want to see permanent magnets do work.
Norman
Floor
Thanks Norman
With a force of attraction between the center magnet and ONE of the outer magnets....
                                     while at the same time...
There is an equal repelling force between the inner magnet and the OTHER outer magnet...
The mechanical linkage illustrated..... will cause these two forces to total to zero force, in the vectors of
toward or away from the center magnet.   The attraction by one of the magnets is equal to the repulsion
by the other magnet, (to the center magnet).
Both of these forces (THE ASTTRACTING ONE AND THE REPELLING ONE) change at the same rate,
as they change in distance from the center magnet (also each at the same rate).
The springs are there to close the gaps, between the two outer magnets and the inner magnet,
when the attracting and repelling forces are equal, because the shield magnet is in place.
Without the shield magnet, the outer magnets repel each other.
                   best wishes
                            floor
