Magnet force shield
Started by Floor, January 21, 2017, 11:14:49 AM
synchro1
Have you tried a vertical gate? The repulsion magnet, guided by craft sticks, can reposition by gravity this way and the repulsion force would be easy to gauge by it's elevation.
Floor
Have not tried a vertical gate .
Move discussion to
https://overunity.com/18511/floors-magnets-explained/msg546731/#msg546731       please ?
floor
synchro1
Quote from: Floor on June 13, 2020, 05:47:37 AM
Move discussion to
floor
Thanks. 7 grams to slide and 1 pound 5 ounces of repulsion force equals a 90 to one force ratio. Perhaps a top rotor in attraction could multiply this by a factor of two? The repulsion, attraction magnets spoked and axled through the center.
synchro1
Here's the twin shield rotor attraction repulsion, gravity assisted axial pumper; Maybe 14 grams of force to power the rotors and 3 pounds of perpendicular axle pressure! That's a ratio of around 100 to 1! We can pulse the rotor with a magnet coil and add a ratchet latch.
This would operate a spring backed pancake pump extremely efficiently. A 3d molded frame would be ideal. The shield rotor connects to the bearing hub protruding from the casing and the bearing also allows the axle to slide.
