Is anyone seriously interested in Free Energy Physics?
Started by aether22, January 22, 2017, 05:31:43 PM
aether22
Quote from: sm0ky2 on February 07, 2017, 09:44:10 PM
No there are no magnets
It's a perpetual electric effect in the magnetic domain
The steel tubes act as magnets until you break the circuit
Ok, so the pipes have a split through them, and a coil is wound over them?  and they are in a circle?
Are they wound like this...
Note also, do they snap closed as shown? Did I represent the gap correctly?
If you don't remember the number, that's your best guess?  8?  12?  odd or even?
sm0ky2
Hahah
Sorry I don't mean to laugh it's just comical to see
Someone else's interpretation
Ok the first image on the left will work
The other two are not right take those coils off
Now why does the first one work?
Because one coil will centered opposite the gap
Will energize the single split tube, and if the gap
Is small enough yes it will snap shut
It would work better if you put two coils on the tube
One in each side of the gap
Twice the magnetic field.
But the other two images that show a bunch of wire
Is incorrect in principal. It will not work.
Take all of them off except the two tubes by the gap
All the other tubes should be touching each other
Now instead of trying to snap shut a single tube
Open the split so it does not close
And when you energize the two coils the gap in the larger
ring of tubes will snap shut.
Basically each tube conducts on their curvature inside the ring.
When you pull them apart later you get a pulse through the coils
That returns most of what you put into it.
sm0ky2
Small items placed between the gap when it snaps shut
Become magnetized. My theory is that microscopic pieces of
Steel or iron get imbedded into the material over time.
I had no real way to test this theory.
But I did have to odd experience of picking up aluminum and
plastics, wood, paper
With a magnet.
sm0ky2
It's not really the magnetic effects that I want to show you
That is really a different topic. Ed wrote books about it.
What Dave discovered was something to do with the
Geometry of the ring of split tubes
I guess it is somewhat derived from the magnetic current
Because the effects did not occur when it was deenergized.
But the geometry of that set-up does something to the light
Above the ring
sm0ky2
The two coils are wound opposite so one side N and
The other S facing across the gap.
You can even use a piece of paramagnetic material to
Close the gap with.
Ed's original PMM was a horseshoe magnet with its' keeper bar.
The difference with Dave's experiments, they were all done without
Magnets. Isolating the effect to a purely electromagnetic realm.
The magnetic loop keeps the paramagnetic material magnetized
Until you break it. Which can be years later, as one experimenter
proved.
