re: energy producing experiments
Started by Delburt Phend, February 04, 2017, 09:31:19 AM
sm0ky2
E= mgh (only when it falls)
If I have a rock that weighs 10 tons
And I lift one end up (leaving the other on the ground)
I am only lifting part of the rock. This is much easier than
lifting the entire rock. (something less than 10 tons)
Now if I place a fulcrum at its center, it will balance itself out.
Literally lifting the other half of the rock for us.
we have 10 tons in the air we can drop.
Let's take two 5 ton weights.
Place a raise bar above them. Center pivot. Tie chains
and pull them tight, and use their balance to pull the chains
tighter and get them off the ground. Like scales.
You may have to dig some dirt then bounce them pulling the chains
tighter to get them airborne.
now: you can move these and spin the bar around with little effort
we have 10 tons flying through the air.
do this with another pair in a "T" shape so it pivots on 2 gimbals
we have 20 tons flying through the air on a 4-way pivot.
Get them spinning fast
now you can get them all swinging up and outwards on their chains.
Now we have 20 tons higher than before.
catching the momentum of these yields an incredible burst of energy
And the Height at which we catch them is higher than before.
Support the weights raise the supports and do it again.
Each time gaining a burst of impact energy 20 tons slamming into something.
Each time 20 tons higher than before.
Each time just little you spinning a perfectly balanced axle with ease.
sm0ky2
sm0ky2
If we want to achieve a sustainable energy footprint
and not be dependent on anything
It is a simple equation.
How much energy do you need?
How many times does your generator need to spin
to make enough power for the rest of your life?
Figure out what kind of gearing this would require to operate a
Gravity drop-weight system at a reasonable height.
Meaning if you had weight X at a height you can build a tall enough
support to, geared down to spin your generator for 50-60 years.
Calculate the torque on that gear at nominal operating rpm.
And then figure out how much weight you need to get up there.
You can compare that to say..... your water bill.
Which will lift the mass of water to the height of your local tower for free.
(at the same rate you pay for water, and needs to be pre pressure regulator
       for max height)
onepower
I like to equate energy in terms I can relate to as a country boy like cutting the grass with my lawn mower. So my household requires 1 KW on average neglecting peaks and troughs at an average efficiency of 30-40% not unlike my lawn mower. So my real world not BS energy needs are not unlike a 5hp generator/lawn mower screaming away in my back yard 24/7.
Now let's take maybe 4 billion 5hp lawn mowers screaming away as residential and 8 billion as commercial/industrial and now we have a little fucking problem. Think of it this way, a billion is a thousand-million so were talking about let's say 12 thousand million generators screaming away every day just to keep up with our current demand. Understand this is only our electrical demand and has nothing to do with heating/cooling or HVAC in the rest of the world.
For example where I live in Alberta and it is supposed to hit -35 Celsius with wind chill into -55 the next few days. If I do not have fucking  "energy" I die unlike many of these pussies in Florida at mar-a-lago who think not being able to charge their phone is the end of the world.
So if were going to talk about energy then lets talk about energy but don't think think anyone just can throw out some bs they cannot justify. I live and breath energy because my life depends on it because I live in a environment designed to kill most people.
Toolofcortex
I have to disagree magneat, the Chalkalis device, was not overunity.
The Chas Campbell device was on a loose wooden plank, as I have shown before on video but it seems someting happened to that.
It may have have had improper weight distribution.
You are not the first to come here and say these things, I have said all this before.
The problem is that we, me , everybody, wont build a proper test bench because small people are small and stay small.
Its a big endeavour to make it the way I want it, and theres cheaper things that show much more promise.
Dominating factor is still money, economics.
