Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
wistiti
Hey guys!
I have made some quick test tonight and have something interesting to share.
I have wound 4 layers of magnet bifi wire over a ferrite stick. I use the first layer as a classic "joule thief " as the primary for the oscillation and connect the rest of the 3 layers bifilar serie to have open end coil as Jack show us.
First try I have a poor output but it's completely lens free!!
I have play a bit with my primary bifi coil and found that when I use it open (connect the oscillation to separate legs/wire of the bifi and leave it open) I have much more power at the output than when the primary is normal close coil! :). It remind me the lorrie matchette device...
This need more investigations!
Thank you Jack !!!
wistiti
Quote from: wistiti on April 27, 2017, 12:24:30 AM
Hey guys!
I have play a bit with my primary bifi coil and found that when I use it open (connect the oscillation to separate legs/wire of the bifi and leave it open) I have much more power at the output than when the primary is normal close coil! :). It remind me the lorrie matchette device as Danways said...
Thank you Jack !!!
Grumage
Hi Matt.
These are exciting times!! Pun intended....
You have made so many posts posing different questions.
Remember Verpies " most excellent " solenoid coil graphic? Showing the field concentration being greater on the inside. Perhaps you need your coils inverted? " ass about face " !! So to speak.
Then you moved onto flat coils, remarking about induction hob's.
You could try this......
https://youtu.be/R9himdPWYQM
It's a rather robust " Royer " oscillator but the beauty of it....... It doesn't need a centre tapped coil.
I'm just waiting on the judges report from the BiFi panel but a few flat coils seem to be the next item on the " to do " list.
Cheers Graham.
Dog-One
Quote from: Grumage on April 27, 2017, 08:46:33 AM
Indeed.
I'm honestly all over the map trying to assemble a puzzle here.  Feel like I have the pieces
needed, just need to get them put in the proper order and stitched together.
I had the same instinct too.  Jack mentioned it shouldn't matter, so naturally I did it
backwards I think.
Pretty certain this is the way to go here as long as the frequency isn't out of range
of what I have to work with.  The BPC is almost screaming to be used in this application.
I had forgot about that one Grum, thank you for reminding me.
What I was going to do is use my Push-Pull setup I built for the Ruslan device and just
use two pancake coils on each side of the output coil.
From what I can see, an open-ended BPC with a tuning cap across the open end looks to
be the way to go here.  That's about all I can say at the moment until I have a chance to
prove myself wrong.
If you saw Brad's video, it sure looks to me like this is a no-brainer to try for this project.
As I mentioned someplace, I don't know if what I'm thinking is actually what Nelson is
doing, but it sure seems like it.
