Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
0 Members and 372 Guests are viewing this topic.
Jack Noskills
Quote from: wistiti on May 14, 2017, 11:57:03 PM
Hi guys! Just let you know I have play a bit with the concept today. I try copper foil as a coil capacitor for the secondary But have not good output.
The best I have until now is with multi layer of bifilar open coil as the output.... more to come when the time permit!
Hope the best to all!
It was a good idea to test using insulated copper foils. There are some improvements that could be done to increase output power.
When copper foil is used to make a coil capacitor it is important to have many turns (or layers). When each layer is over previous layer the electric field between layers is increased. Doubling the amount of turns increases output power four times. Thickness of insulation that is used with the copper foil is directly related to available output power. Thin insulation increases and thick insulation decreases it. If you need more power then add more turns. From the pictures it appears that the copper foil you are using has insulation on both sides of copper. One layer could be removed to make more effective system, if possible. Distance between layers would be halved so output will increase four times. Adding these two improvements in the same system and output power will increase sixteen times compared to what you have now.
I realized why turn offset increases energy output: it does voltage pulsing! Now the test system becomes a lot easier to make as there is no need to use separate voltage pulser. I cannot imagine where to put charge collectors in this system so they can be left out. Take a plastic tube, use small diameter to get many turns but large enough so that you can put in any ferrite you have. This will be useful when tuning the system. Then tape one foil on the tube, second on top of first, then third and fourth layer. Now you have four stripes attached to tube and you can start winding them all at once and make a tight wrapping as you go. Take outputs from the start and end of wrapping from every foil. With four layers you can experiment with coil offset by cross connecting the layers so that you will have two segments for coil: layer 1 connected to layer 3 forms the first coil and layer 4 connected to layer 2 forms the second coil. On top of this coil capacitor you can make the Joule thief primary winding. In case you have only two copper sheets to work with then use only two layers, unless you are willing to cut one foil in two parts and connect it as shown in figure 3 of the pdf. Use of turn offset more or less doubles the output power. Using both outputs at the same time also doubles the output power. Adding all these together you would get 64 times more output power compared to what you get now.
One test could be to try tuning the Joule thief by moving the ferrite core and create a standing wave in the coil capacitor.
Jo-EL
Quote from: Magnethos on February 09, 2017, 01:16:18 PM
I have read a little of the document fast and it looks very good.
I would suggest to read also another document that can be complementary of Jacknoskills' one. If someone is interested in the second document, let me know it here and I will search and publish here the name of the document.
I am interested in the second document, please let me know were to get it !   ?
Jo
Reason1st
Quote from: Magnethos on February 09, 2017, 04:54:31 PM
I have the book in paper, so I don't have a link.
They are two books, called "Energy conserver theory" George Wiseman.  The book explains:
"Heat, light and magnetism are side affects of electron flow and do not 'consume' electricity." 'Electricity' is lost in conventional circuits when the source neutralizes itself (electron density equalizes)"
It explains more detailed than JackNoSkills pdf document and it explains very similar theories. Wiseman also explains about "electron density equalization".
Jo-EL:
Later the same day Magnethos posted that it turned out he was referring to two books so he did not have a document link.  If you want to have a better idea about what the books cover I found that George Wiseman uploaded free previews to his two books on Scribd, here are the links:
https://www.scribd.com/document/130668249/Energy-Conserver-Theory-Book-1-preview
https://www.scribd.com/document/130669592/Energy-Conserver-Theory-Book-2-preview
forest
Quote from: Reason1st on May 19, 2017, 10:22:54 PM
Jo-EL:
Very good theory. I agree and I could add that the source of energy is magnetic field - electrons are like little magnets and their magnetic momentum is what create macroscopic magnetic field which is the reason for heat,light, magnetism.
