Pulling energy from the ambient energy field using a coil capacitor
Started by Jack Noskills, February 09, 2017, 07:41:34 AM
0 Members and 123 Guests are viewing this topic.
Belfior
yeah my results  differ so much from his I wonder if the spark gap and higher voltages & ferrite core is what produces his effects.
I am going to redo all my experiments with proper measurements as soon as I this move done. Hopefully I will also find all my gear after the move.
I have no doubt that there are some weird effects with these coils. I already got some bulbs to light up with some open ended coils. My test was primary over a ferrite core and then 2 open ended secondary coils around the same core. Secondaries had one end left open and then other end connected to a light bulb. So open circuit but the light turned on
antimony
I just wanted to comment on something Smokey wrote about twisted coils.
I saw a increase in output when i added a twisted pair over a regular bifilar pair, so it may be correct, but i will not bet my life on it becouse the increase in light output is all that i have to back that up with. :)
itsu
I setup my coil system as shown in the Fig. 6 in the PDF, not sure if that is needed, but the
'Signal generator testing guidelines' section in the pdf, where i am now, says so, see the picture below of this setup.
Using UF4007 diodes and a 230V GDT.
Not sure where to attach the FG, so i loosly coupled it in on the inside of the tube.
Screenshot shows the FG pulse in blue and the response of the load (across the GDT) in yellow (load is only the scope pobe).
The ringing downs (one at start of the pulse, one at the end of the pulse) show a 208KHz ringing frequency, so no where near
the measured 3.5Mhz resonance frequency of the seperate coils.
Video here:  https://www.youtube.com/watch?v=bNFi2KdUqKA
Need input from Jack if i am on the right track.......
Itsu
Jack Noskills
Use one coil capacitor to give pulses and the second on top for output. Three turns primary is not enough. This pulsing method comes from wistiti's experiments here, I have not tested it myself.
Capacitor charging effect is what should be studied after resonant rise has been achieved. Resonant rise as a phenomena can be found from the net, better that I do not try to explain it.
itsu
Thanks Jack,
i will loose the diodes and GDT for now and use the first layered coil as pulse drive coil.
Did you see the comment from Void about that?  See here:
http://overunity.com/17119/pulling-energy-from-the-ambient-energy-field-using-a-coil-capacitor/msg514965/#msg514965
Resonant Rise seems to be some kind of game as that is what google presents me.
Are you not simply talking about the (normal) situation that when a RLC circuit is in resonance its (voltage/current) amplitude will increase, see here:
https://en.wikipedia.org/wiki/Electrical_resonance
What about the prototype coils i have?   Is it what you expected?   I would expected to have some longer coil (20 or 30cm long or so)
I have seen pictures in the thread from woopy and DogOne showing different layout (longer) coils.
Some answers on questions you asked via PM, the rest will follow when i have them:
- Measure the capacitance of the energy collecting coil capacitor.
  if this is the 2e layer coil?      its 1.95nF
- Can you see the waveform of the impulse response, is it a damped sinusoid or is it tubular ? How long is it ?
  See the latest above screenshots; damped sinusoid, 216us, but this is with the Fig. 6 setup, so with diodes.  What is tubular shaped, like a trumpet?
Regards itsu
