TOTAL SUCCESS OVERUNITY TESTS, RDG LAFONTE GROUP
Started by Butch, November 18, 2006, 02:28:36 AM
Butch
We have successfully designed and tested a machine that reverses the electro-magnetic forces involved in the operation of the basic magneto. The electro-magnetic field strength during the approach of the rotor to the stator increases the pull on the rotor rather than decreasing it. A diode in the circuit keeps the pull on the rotor during exit from the stator the same amount it would be if it was just a magnet leaving a piece of ferromagnetic material with no electro-magnetic field influence. In other words more force going in than drag going out. We used a very simple test method that is fool proof to get the test results. I have included the test sequence below.
We have built two identical machines except one will be wound for high voltage and one for lower voltage. My low voltage machine will be shipped to me and we will replicate tests results. Thanks so much to all the members of the LaFonte Group members for funding, parts, test equipment, 3D animations, machine shop work, moral support and believing it could be done. The final product is so simple, I always figured it would work out that way. This technology will not be suppressed. Things are set up to flood the internet from locations other than the group locations with all information needed to understand, build, and operate the device should any suppression take place. I will be allowing anyone to view the device operation and testing when my unit arrives here. None of this "it works, but you can't see it" stuff we have all had to deal with in the past.
Thanks to everyone who has helped me now and in the past.
This is only the beginning of many overunity machines from this group.
Butch LaFonte,
The LaFonte Group,
Reaction Diverter Generator
allcanadian
Hello butch
Have you ever tried using a true tesla bifilar coil on the stator, A flat bifilar coil like tesla patented with a small iron core like adams used? I was throwing this idea around before I test, like adams motor I would route induced power to a Cap when the magnet approaches register,open the coil circuit at register to stop all forward current flow thus stopping backdrag, close coil circuit to dump the Cap to a battery. The current flowing from the Cap,through the coil to the battery is then a true current reversal thus repelling the rotor PM with the same force coming into register only the energy gained on approach goes to the battery.
If you have tried this I would appreciate your input, so I am not repeating experiments.
Liberty
Quote from: Butch on November 18, 2006, 02:28:36 AM
Butch LaFonte,
The LaFonte Group,
Hi Butch,
Sounds like you have found something pretty special!
It sounds like a modification that is fairly easy to do from your description above.  Will this method of eliminating the reverse magnetic pulse that creates resistance during power generation be able to be used in standard existing alternators, like your car alternator or diesel/gas genset?  Or is it used in a specially designed configuration only?
Liberty
lltfdaniel1
never under estimate satan, be very careful with this stuff, if what you are saying is true,big oil and billionaires are not going to take this lightly,controling people not knowing what they are really doing.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
