Leedskalnin's Perpetual Motion Holder in Electic form
Started by sm0ky2, February 24, 2017, 11:16:20 AM
tinman
Quote from: Doug1 on April 05, 2017, 08:14:38 AM
Ed did not use ferite materials. The PMH is not about residual fields. It can be used to clarify a number of theories and used as tool or device for observations. Building one is a ok project but you can also use the electric break section from a wheel chair motor. I had one stayed charge for a number of years even thought i lost it or threw it away at one point but it turned up in a small decorative wicker basket. I think it was sitting for about 5 yrs. I flashed it with a 12 volt battery and left it . Inside the break is a hefty spring that will push the keeper away if the magnet is turned off. When I broke the connection of the wires the keeper flew off and bounced off a wall.
  It really just locks the flux into an endless loop so long as the wires are connected the same way an endless loop. Break the wire connection and the field collapses. I would venture a guess if you were able to break the keeper away and you were prepared for it as a test you could measure a temperature rise in the coil if it was kept connected when the keeper is forced apart. It proves if a magnetic field is given a path that is a continuous loop and if the flux was created with a current that is looped they will continue indefinitely. It's all about closed loops, ya know that thing that eludes so many. The impossible non existing possibility that there might be something more then a beginning and end to everything. Everything is born and everything dies. So where did it come from and where did it go? Poof in and poof out I guess.
Doug
The wires do not have to remain connected-the coil can be open once the keeper is magnetically locked.
Brad
Zephir
QuoteThe wires do not have to remain connected-the coil can be open once the keeper is magnetically locked.
But after then it's just the magnetic remanence effect, which @pix is talking here.
Once we use ferrite with no remanence, then we'll see the true Leeskalnin effect.
leonelogb
I congratulate to  sm0ky2 for start this thread and the way that how he has been share these information to us.
And to Other guys with excelent knowlege!  ;D
Iknow that the PMH is the KEY but...  I have been trying to know how the PMH work and I have some questions.
What is exactly in moving?  ???
can I test this moving?  ???
why or how it put more speed to electron? :-\
Thanks!
dieter
there are several attempts to explain rhe PMH. Maybe the most plausible is, both sides are temporarily magnetized and each side prevents the other side from relaxing the magnetic domains.
Even if trivial, it does contain a nifty effect that may be exploited somehow.
I don't think anything is moving tho.
dieter
Well let's take this a little further.
Assume we'd have a torus core instead. If we pulse it once, the core will hold the magnetism idefinitely. like the PMH. This were the first Rams, a bit each core. Anyway. Now, assume our secondary pickup coil is at load only after the pulse ended. If the core now somehow leaks magnetism then the strength will drop and current will flow, while the primary being passive, is not affected, or could even work in pickup mode temporarily too.
How to make a toroid leak? Maybe by injecting ultrashort counterpulses, to initiate a recursively exponentional domain relaxation? Maybe by a short cut over the center? Or by external fields? We do not need to compensate a PM here, only initiate the natural relaxation.
Interesting stuff.
