Mervace Working Magnetic motor using induction feedback
Started by Jdo300, November 20, 2006, 01:26:19 AM
Omnibus
@Adzoe,
Carefully observe that in Naudin?s experiment the energy to place the ball at the beginning of SMOT is even smaller than the energy to place the ball at the beginning of the control experiment. I told you this but you?re not reading carefully. Nevertheless, the energy obtained in the SMOT is greater than the energy obtained from the control experiment. This is in violation of the energy conservation principle. Please read carefully and try to understand the explanation because otherwise unnecessary clogging of the thread occurs which isn?t even a thread devoted to SMOT (although, ultimately, if mervace?s device shows a real effect, it is closely connected to SMOT).
Same arguments apply to the closed A-B-C-A loop. It is not true that I am not considering the energy needed to move the ball to the beginning of the SMOT in my calculations. I?m telling you again, you don?t understand the argument and it would be better to give it a little thought before posting.
AllPlease
Omnibus, Please do not start another endless rant in support of SMOT It's off topic. Please we had enough of your erroneous assertions on the "other" forum. You have over 2000 posts there. Please!!! There are plenty of other SMOT threads in Overunity.com. please spare us the torture in this thread.
@All
Please do not reply any SMOT discussions here.
Let's focus on what Merv has to say and the device at hand. Merv's device is one of the most interesting yet.
@Merv thank you for taking the time to join and provide information
Thank you all.
Omnibus
@AllPlease,
Exactly because of assertions such as yours these threads are turning into endless exchanges. You are wrong and you have to know this. Don't answer more because if you continue I will too.
Also, it is not true that this thread isn't connected to SMOT. It is. You obviously don't understand that and therefore it would be better to restrain from clogging the thread with your useless comments.
Adzoe
Quote from: hartiberlin on November 23, 2006, 11:38:22 AM
Ahh, I see,
you mean the rotating magnet is attracted to the iron
twisted pair wire and so will accelerate as in a SMOT ramp
and then induce current inside the center coil ?
This could also be the case, right ! ;)
Good idea !
I find it impossible to imagine a ferromagnetic material having any benefit in the twisted wire "gimmick".  Any iron there would merely slow the rotor, as the gimmick is too far removed from the solenoid to create a magnetic field strong enough to attract the neo magnet downward.  Anyone out there with a gauss meter to test this?
allcanadian
Hello
The answer as to whether the twisted pair is iron or not should be obvious, Does the long wire move when the magnet passes by in the video? No    A long metal twisted wire anchored only on one end would move a noticable amount if a magnet was anywhere near it. hence no iron.
