3.7 VOLT BATTERY POWERS 56 WATTS
Started by magnetman12003, March 28, 2017, 07:46:43 PM
SkyWatcher123
Hi all, Hi magnetman, thanks for sharing, that is what matters, that we all share to help benefit one another.
I'm glad i bought these 12 volt led bulbs.
Because with the inner circuitry removed, 4 of them in parallel, are now as bright as the old model 6 watt eco smart bulbs i was using.
Though instead of using 4 watts, these are using 2.5 watts with the usb power supply.
The circuit is a little different than i previously posted, just one diode off collector, then into led bulbs with capacitor in parallel with led bulbs, so more like a typical joule thief arrangement.
It's the low voltage led boards, that is really helping the efficiency here.
Also changed the transistor to a TIP3055 NPN.
peace love light
magnetman12003
Quote from: SkyWatcher123 on April 25, 2017, 02:26:04 AM
peace love light
I just did another system test and found with all bulbs lit brightly I had 6.2625 watts  measured between the 17 watt USB adapter and the setup.  All other system watt values I measured were lower.  So the big question now is how is 63 bulb watts powered by 6+ watts which was the highest value measured ??
Waiting to compare results from anyone who has gone this far.
SkyWatcher123
Hi magnetman, I am also having good results, though i switched to 12 volt input, since i'm using the 12 volt gutted led bulbs now.
It is definitely brighter than the previous video i shared of the ecosmart bulbs.
The oscillator is powering 5 gutted 12 volt led bulbs at 11.81 volts at 280 milliamps or 3.3 watts.
One of them is a 6000k color temperature bulb and is a little brighter than the warm white.
They sent me the wrong bulbs, oh well.
https://youtu.be/jBcPsE0m1y0
peace love light
magnetman12003
Well that's two of us and possibly more persons later that are having good luck using this startup LED low power technology.
I wonder when someone wakes up in the automotive industry and sees the light.
Auto components can be downsized starting with the alternator and all wiring if LED bulbs are employed. Less weight.
That in itself should be a wakeup call.  Get a excellent team of engineers on this and no telling how far it may go. Don't need a lot of current to push through the wires any more.
I also have to mention that it could be used to light up places that are impoverished because the cost of electricity is beyond reach.  With a low wattage setup like this it becomes a viable commodity.
No the electric companies won't go out of business they will only get more customers,
Its a win -win situation for all.
It my hope a lot of persons takes this to heart.
Ed morbus
magnetman12003
have you more info for total cable wire length and how many ohm
