3.7 VOLT BATTERY POWERS 56 WATTS
Started by magnetman12003, March 28, 2017, 07:46:43 PM
magnetman12003
Quote from: Zephir on April 18, 2017, 08:01:21 PM
Hello, magnetman
and thank You for your reply, albeit it sounds quite intriguing for me..:) Your power enhancer behaves a bit like the Bedini motor or something similar. According to this video the brightness of LED bulbs and voltage at input doesn't change, once you stop the magnet, but the current consumption of your device increases from 0.94 to 1.28 A or so. Which meaning the magnet rotation actually has under such a situation?
Thank You for Your support!
I have made many changes to simplify the setup since 'this video' was made. No need for hi voltage to power it.  Now I only use  5 volts and a little over 1 amp. The magnet rotation draws more current but is not needed once the bulbs in this case are lit. Then the magnet can be stopped.  The newer bulbs I am using now don't require a magnet or magnet spin at all.
SkyWatcher123
Hi all, Hi magnetman, i ordered some more led bulbs to be sure i have extra just in case, plus i wanted to have the same amount of bulbs you are using.
Here is the link.
http://www.ebay.com/itm/252338553207?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITI
peace love light
SkyWatcher123
Hi naija, i just noticed your reply, thanks for the kind words.
It works fine with an air core, i would use 24 awg. magnet wire or the telephone wire like magnetman, if you can't get any magnet wire.
I would also use the brooks coil geometry for an air core coil, i didn't, because i wound it for the option to slide in my ferrite c-core.
The components shown or equivalent should be fine, since the capacitor shown has high enough voltage rating and those 220 volt led bulbs will be using less amperage.
The only question is, will the led bulbs you use work properly with the circuit, if not, you may need to remove the inner circuitry and just drive the leds directly with the diode/capacitor output.
I plan to use the 12 volt led bulbs i should be getting in mail soon and also plan to more closely build the magnetman circuit.
peace love light
magnetman12003
Quote from: SkyWatcher123 on April 19, 2017, 10:26:56 PM
peace love light
I just got the very large USB power adapter in and tried it.    5.08 volts shows at its output but strangely  the output across the circuit capacitor C1 shows 1.55 volts and climbing with all 8 bulbs burning very  brightly.  The USB  adapter is cold to the touch. (Orange LUMSING WITH 2 USB PORTS)   I am happy.
https://www.amazon.com/gp/product/B0132X03ZS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Here is what the spool and 1000 ft. of cross connect 2 strand wire looks like. Must cut down to 740 ft. size.
http://www.ebay.com/itm/NEW-Roll-of-General-Wire-cross-connect-2-C-24AWG-1000-wire/252875098432?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40130%26meid%3D281358708da24f73a9348a5ceead02c8%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D172624728257
Want B7A neon bulbs?
http://www.ebay.com/itm/Box-of-10-Neon-Bulb-NE45-B7A-Indicator-105-to-125-Volts-AC-DC-/162458540245?hash=item25d34898d5:g:XaQAAOSwA29Y5Cd9
Want 80 ohm automobile relay?  Use pins 85/86 for direct coil contact.
http://www.ebay.com/itm/Herko-Bosch-Style-4-PIN-Blade-Post-Relays-SPST-80-Ohm-NO-40A-14VDC-NC-30A-14VDC-/360919592949?hash=item54087beff5:g:mHIAAOSwmLlYAA9T&vxp=mtr
magnetman12003
Added another bulb.  63 watts now powered by 5 volt  USB adapter.
https://www.youtube.com/watch?v=FYfbgapZYhc
