Magnetic, And, Gravity, Motor, Update, And Notes
Started by guest1289, March 29, 2017, 06:50:27 PM
sm0ky2
Quote from: dieter on April 08, 2017, 05:12:35 PM
But gravity isn't directly substitutable by magnetism. As there is no repelling in gravity.
It is this difference between two conservative fields, that allows energy to be extracted
between them.
I refer to this as the flux-to-mass ratio of a given pair of magnets.
It is related to the gravitational field, but of different magnitude and without the
time constant.
E=mgh and the mass and height lifted by the opposing magnets (maximum)
The greater the flux-to-mass ratio, the more mass is lifted higher.
sm0ky2
@guess1289
You propose an interesting scenario.
What happens if we send an electric current through a wire
Around the circumference of a centrifuge
In the direction of rotation?
Technically (and I mean by technicality) we would have a
superconductor.
postingsite
Quote from: sm0ky2 on December 06, 2017, 07:56:11 PM
@guess1289
superconductor.
I wonder if there's a useful invention there,   an easier more convenient way( in various situations ) to achieve  'Quantum Levitation'
If,  by using your idea,     'Quantum Levitation'( https://www.youtube.com/watch?v=Ws6AAhTw7RA ),    could be achieved,    would that prove or disprove  the  'theory of relativity'  regarding constant speed of light
And what about if you implement your idea,  by already using superconductor at the start
postingsite
@guess1289
superconductor.
I forgot to add something to my post 15 minutes ago :
http://overunity.com/17203/magnetic-and-gravity-motor-update-and-notes/msg517155/#msg517155
Your idea ( possible invention,   may have been,  or may not have been,   inspired by guest1289  's post :
http://overunity.com/17203/magnetic-and-gravity-motor-update-and-notes/msg507817/#msg507817
( Note - Your idea does not seem possible using guest1289 's described design,  only the design you suggested may( or may not ) function successfully,  but may depend on the correctness of  einstein's theory of a constant speed of light )
For example,  as the centrifuge component spins,  coils placed on the rim of it's outer circle-perimeter could be acted upon by an external stator-permanent-magnet,  in order to power your idea,  and via your idea     'Quantum Levitation'( https://www.youtube.com/watch?v=Ws6AAhTw7RA ) could be achieved
sm0ky2
I believe Einstein to be correct, in that c is constant for local space-time.
However, the actual value of c may vary from our location to another part
of the universe.
So, the experiment should confirm Einstein's predictions.
even though they may not be entirely correct.
