Some Bifilar coil experiments
Started by evostars, April 11, 2017, 04:31:06 PM
evostars
I've made a video showing the working experiment producing 950Vdc:
https://youtu.be/KbtK9jrk_JI
Ambient9
Quote from: evostars on April 12, 2017, 08:09:23 AM
Great job! Well done! very interesting experiments!
Have you tried to measure the current with a load? or even to make a closed loop?
Keep it up  ;)
dieter
Very impressive, thanks for the vid.
The caps load in about 1 sec, that's about 1.6uF * 900sqr /2...about 64 millijoule/s.
Anyway, it would be easier if you used a certain load, such as a 100 Ohm resistor, then you measure amps * volts = watts, and compare it with input watts. It is however an unusual way to step a voltage up. A standing wave does that. From my POV the art of profession would be an automatic frequency adjuster that compensates for the output that usually kills the resonance.
Anyway, interesting stuff.
shylo
I don't understand why everything turns into a pissing match.
TK is very smart ,Listen to what he says ,answer his questions ,if you can ,if you don't understand ,say so.
If the question is lacking in understanding ,then explain why.
I find this very intriguing ,if I could raise my voltage to those levels, I would think a self runner is inevitable.
I'm not sure I understand Evo ,your pulsing the middle coil, and the two outside coils are putting out 900 volts?
I do agree ,keep all the bullshit contained to one thread, there's already enough around.
Looking forward to more of your work.
Thanks artv
evostars
Quote from: dieter on April 12, 2017, 02:06:40 PM
Thansk dieter.
Yes the resonance needs to keep going. How to drain the caps, without disrupting the ac(topcoil)-dc(2x2 caps)-ac(bottom coil) path?
The energy is not related to the square root of the voltage, but the square of the voltage. the uF needs to be in farads.
11,68V input gives:
E=0,5*0,0000016*900*900=0,65 Joules
when i used 19 volts, it became 1500Vdc
E=0.5*0.0000016*1500*1500=1,8 joules
Speculation from here on: The ratio between voltage in and out is around 77,
So if i would use 55V *77 would produce 4235V
E=0,5*0,0000016*4235*4235=14,35 Joules
110V dc input *77 is 8470V
E=0,5*0.0000016*8470*8470=57,39 Joules
Do you see where this is going? 10x more input voltage, gives 88 times more output energy. (yes speculation, but based on the squared voltage).
A question rises. What about the input amperage?
My setup is far from ideal right now. The IGBT produces short sharp pulses, but, It does so by basically shorting out the power supply over the center coil. and this it does 50% of the frequency. I really need to fix this, before I can make a proper measurement. The Igbt should open and close very shortly. Another challenge to overcome.
Its again a speculation, but I think, to pulse the center coil i need a high voltage, but a relative low current. (like discharging a capacitor)
In the most perfect setup up, the center coil would also be pulsed at its resonant frequency (its not right now).
Far from perfect. but, worth the investigation.
edit: yes the standing wave, is what happens at the resonant frequency.
I like to compare it with water. If water is standing still, the waves apperently move over it(the water just moves up and down).
But when water travels fast, and it moves around a object, a standing wave is produced.
So the ether can move up and down, but with a standing wave, the ether is moving fast.
Now we have 2 coils (upside and downside) with standing waves.
The ether is moving fast, around both coils, at the same frequency.
to me it seems the ether flows, are interacting, producing the quick rise in voltage(pressure) in the caps.
