Free energy from watter - a review of research
Started by Zephir, April 22, 2017, 02:08:06 AM
Zephir
Nearly all devices involving water were reported with overunity, if we order them by energy density scale:
1) free flow wheel (Bhaskara)
2) bubble buoyancy generator (GAIA ROSCH and older ones)
3) cavitation heaters
4) water combustion engine (Meyer)
5) dozen kHz water membrane generator
6) 13.56 MHz radiowaves (Roychowdhury, Kanzius)
7) 2.5 GHz microwaves (Vaks, Zographos)
8 ) 0.6 - 200 MHz discharge (Energoniva)
9) low voltage/high current discharge (Brilliant Light)
10) plasma electrolysis (Mizuno, Bazhutov, etc.)
If these devices all work at least under specific circumstances, then there is low probability, that the very same mechanism will be involved at all these cases. I can see some similarity between negentropic behavior of magnetic domains in ferrite OU devices and small bubbles (oversaturation, hysteresis and size dependence).
Zephir
Interesting overunity (?) device based on high voltage & frequency pulses introduced to membrane for reverse osmosis with COP > 120. Device is able to heat 500 grams of water from 22 ° C - 93 ° C during 720 seconds with using of battery input 1.7 Watts. Average life-time of membrane is 35 minutes. YT videos 1, 2. This device wetted my interest, as it show the way, how to do plasma electrolysis without actually doing a plasma. As you can imagine, during plasma electrolysis lotta energy gets wasted for formation of vapor film at the electrode and its ionization. This film is necessary for reaching sufficiently high electrostatic gradient, but its formation costs lotta energy. In addition, high frequency spikes are formed with less or more random interruption of arc discharge by cooling of film, which isn't apparently the way, in which the optimal frequency and voltage could be adjusted easily and precisely.
The main secret of this device is apparently the semipermeable membrane used. The usage of deionized water of lowest conductivity as possible is recommended, as it would enable to localize the electrostatic potential and avoid shortcuts. The voltage used is AC only without any DC component and from audioanalysis of video it seems, the frequency used is somewhere around 10 kHz. Such a voltage can be generated easily with AC source for ozonizers. Bellow is commonly accessible wholesale kit for reverse osmosis, IMO it could be directly used as an improvised reactor, once you solve the removal of excessive heat produced in it. Membrane must be kept wet after first usage, or it could be destroyed during drying.
The membranes for reverse osmosis can be purchased easily too. The nice point about commercial reverse osmosis membranes is, they're already designed pretty well like the heat exchanger. In addition, they enable to insulate electrical inputs each other very well. The drawback is, they have high surface area. In the above demo, just one square centimeter of membrane is able to work with 2 Watt input. Whereas even the smallest commercial units have surface area by many orders of magnitude larger - around 0.45 m2 i.e. 4.500 cm2. One of possible solution is to use the filter unit in its original form, but to load it in pulsed regime with duty cycle within range 1:100 to 1:1000. The commercially avialable power sources of carbon dioxide lasers are able to manage it with TTL logic.
alpersddk
Quote from: Zephir on April 22, 2017, 02:10:33 AM
I will try it if you write building instructions..
Alper
Zephir
Hi Alper, the original demonstration utilizes very clean (deionized) water for to eliminate ohmic loses and a simple reactor represented with short plastic pipe. The reactor is separated with membrane for desalination of water by reverse osmosis, which one can buy at many places of the web as a wholesale kit (see bellow). The membrane is pressed/glued into a hole at the middle of pipe and inert electrodes (stainless steel or preferably platinum) are leading voltage bellow and above the membrane. All the rest of electrodes must be indeed insulated well for to avoid short circuit through water outside the electrodes.
I even think, that it has a meaning to use the whole kit as it is, because it's perfectly nonconducting and it allows to introduce the high voltage at both sides of membrane simply by inserting the inert wire electrodes (not iron, aluminium or other metals clogging the membranes) into its outlets. The membrane must be washed carefully from salt residues after manufacture and soaked with water according to instructions for its normal usage. Because the membrane will have high resistance and ohmic loses after then, the kit must be passed with clean water for to provide sufficient cooling of it.  The main problem will be, you'll need a very powerful high voltage source for to maintain sufficient voltage across the membrane due to its large surface area inside the kit - so you'll have to apply it in short pulses.
Therefore for first fast experiment may be easier to cut a smaller piece (circle) of membrane and use it in stationary arrangement, as demonstrated at the video above. Whole the device is powered with high frequency source of high voltage, which you can also buy ready made. IMO the voltage source for ozonizers could also work well. The video says, that if we introduce this voltage into desalination membrane, then it will heat itself with power much higher, than the power consumption of this circuit.
This device has interesting connection to Dudyshev's patent, which claims to produce the HHO mixture (Brown gas) with overunity with using of electro capillary effect. Therefore with using of DC current instead of AC it may be possible to produce hydrogen instead of just heat with overunity.
alpersddk
Quote from: Zephir on April 23, 2017, 08:30:18 PM
Why membrane is glowing at the video,if there is no plasma discharge? Thanks.
https://youtu.be/bxWuo2GCkrQ?t=891
Alper
