Dr Ronald Stiffler SEC technology
Started by antimony, April 25, 2017, 09:09:27 AM
Slider2732
OK, so now to Dr. Stiffler's latest vid and schematic, as best I can.
Without having a similar Cree board or a settable power supply, input voltage is still the 5V USB wall adapter.
A 1W LED is on quite a thick stock heatsink, that many will be familiar with.
Pigtail cut off on the L3.
The reverse AV plug is made of 2x 1N4148's, connected to the input supply negative.
Input is 50mA, as measured with an Innova 3300 DMM and output seems to be in the ball park of 1/4W from the LED.
So in other words, it's lighting the 1W LED at approx 1/4 full rated output for 1/4 the rated input...very little in the way of losses if any.
There's also no faux ground now on the homemade SEC 18, which is an improvement.
NickZ
    Hello Slider:
   Although I forget his name now, there was a guy that showed lighting 100 leds, with the previous Stiffler PSEC Exciter circuit. Using no input source, just connected to a ground line.
And that was a few years ago. Has there been any advances since then?
  The Doc gave up on his own self running circuits, a while back, and went to other projects instead.
I guess that he's been sick, all this time?
   Remember that there is always stray AC running through your floors, tables, metal surfaces, etz, and also on any electronics connected to the grid. Which can also light leds on an AV plug.
You need to turn off your house breakers, to be sure that the stray AC is not the cause of the "effect", on that type of low voltage device.
   The stubborn Doc would never show his device working outside and away from man made sources. His ground line was always connected to the AC grid ground rail, instead of to an outside Earth ground.
   Isn't the idea, that the PSEC is supposed to self run? Not lighting the bulbs at 1/4 the normal input, and only getting 1/4 the normal  output... That doesn't sound like any gain, to me, as I understand it.
"Very little in the way of losses"  sounds more like, very little in the way of gains.
Perhaps I missed something...
Slider2732
Hey Nick, long time no chat !
My homemade version will be only a slice compared to a real SEC 18, but seems to work ok and I was pleased with this test. There's not a lot to jump and down about, sure, but it also looks like Dr. Stiffler has only posted that first video to get back into things again.
As it stands, the experiment worked like an re-introduction (to me anyway) of this different form of wireless energy circuit.
Using a ground line to an outdoors stake should help the system out quite a ways...will be testing such things myself.
And yes, very valid point, there are all sorts of things going on with mains, capacitances, perhaps even wifi, phone and radio signals in some cases.
NickZ
  Slider:
  Good to hear from you too.
   Don't forget about Stiffler's "spacial resonance" factor, possibly his unique key to self running.
Bigger coils might yield higher outputs,  along with a tuned earthground
   I do miss the old fart. Good to see him doing his thing,  again.
antimony
Oh Nice to see people are active here in this thread.
I was just going to post that Dr Stiffler has recently posted a new video on his channel called, and i was pleasantly surprised that there were people posting here. :)
I have also missed him, although i wasnt rhere at the time. But i am glad he is still active.
Ps. Are mikrovolt here on OU too?
