THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
v8karlo
Point 2 and point 3.
70-200 turns.
How many turns should be used?
There is 16900 possible combinations.
Or the number of turns are not important?
Just pick some number and go with it?
Why round numbers 70 and 200?
Is it some approximation?
I did not found any explanation for this.
Will it work with less than 70 turns and more than 200?
If there are so many people replicated this successfully, how nobody is posting about it?
Not even at his forum.
bistander
I stand corrected. Tungsten is normally used for bulb filaments. Its coefficient is 10 times that of nichrome. But still, at higher voltage and current, it should show increased resistance.
bi
v8karlo
I am going to make this thing, to see what happens.
v8karlo
Quote from: bistander on June 30, 2020, 03:51:35 PM
bi
Chris is decades in front of us (his words),
maybe bulb is from the future?
So it is possible.
v8karlo
If I make primary 5 turns and 2 secondaries 14 turns,
divided by 5.
IT should work if I raise frequency accordingly , right?
Why to wound so many turns, when the number of turns (ratio) can be regulated by adjusting the frequency?
Ordinary thing, just like in inverter.
Chris should know about this.
Or for some reason his device can not work with some other frequency and ratio of turns accordingly to frequency.
His instructions are little bit partially made. Like he did not think about it.
Weird!
