THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
WhatIsIt
Qoute from Mr Sykes
I have thick Skin, it doesn't phase me, actually all this publicity is something one just cant buy
End qoute
Because I can not post on your thread, you delete everything under my nickname. I post here.
You have thick skin, which is obvious.
And publicity you can not buy, but can achieve here on overunity.com because we are all sheeps and you are using this site to promote yours.
It is so obvious.
But, lets forget your atempts to make money ans publicity,
do you have anything to offer?
Forget about your videos and commercials, they are useless to this site.
Have you anything for real?
Or, you will milking your members for money forever?
WhatIsIt
Qoute from Mr Sykes
More people report Successful results by replicating my work than any other! I mean so many people are getting results, and some really good results,
End qoute
Well, you see, here is the problem.
I dont trust most of the unknown people.
I trust the one with high tech gear , and his word is: bust!
You should pay attention to power measurements.
Source power and output power. Everything else is play with variables.
Stay well and good luck in milking your members for money.
WhatIsIt
Quote from Emjunkie
I do not plan to show my hand, others are doing this for me!
End quote
You never planned to show anything.
And you use that poor researchers for your goals.
You are waiting for others to invent the thing for you,
and then you will erase posts of that person and claim the thing as yours.
Bifilar coil has its secrets, but is not your invention.
If we all going to regret, and you alone will be king,
Will you miss me?
Kiss!
color
EMJunkie
I see sour Grapes!
Three Videos:
https://youtu.be/sDFvKJCW9WI
https://youtu.be/vMXaA0zlb-M
https://youtu.be/pioohhRyfHk
Quote from: EMJunkie on April 23, 2020, 06:52:38 PM
My Friends,
I started Partnered Output Coils - Free Energy back in January 2015. It was a success and Partnered Output Coils is now part of every serious Experiment today!
While some struggle, others report great success.
The biggest problem we had was, we could have done the release and Introduction with several hundred less pages on Stefan's Forum! Far too many trouble makers! Yes I could have handled myself a little better, but when one gets Attacked all the time, one tends to get a little defensive.
We Introduce: Partnered Output Coils - Builders Group
Chet ( Ramset ) and I are the moderators. There will be opposition, there will be some that don't like being moderated, we will be fair, we will only moderate what we need to! We aim to keep the Trouble makers out and the Motivation High!
No one is twisting your Arm, you join in and participate if you want to! This is your Choice! If your not participating, then please refrain from posting. We want those that have experience posting and all here to help each other.
   1: Off Topic Posts will be deleted!
   2: Posts containing Harassment will be deleted!
   3: Slanderous Posts will be deleted!
I urge all interested parties, Gear Up, we are gonna break new ground! I will do the best I can to help others here! My Team must always come first however, but I am serious, I want every human being on the planet to have the opportunity to learn something amazing and simple!
   1: Input Coil - 10% Duty Cycle starting at about 3 Volts into 25 turns 1.2mm Wire.
   2: Secondary Coil - 70 - 200 Turns 0.8mm wire - Opposes the Primary, use the Right Hand Grip Rule.
   3: Tertiary Coil - 70 - 200 Turns 0.8mm wire - Opposes the Secondary Coil, Assists the Primary Coil, use the Right Hand Grip Rule.
Make sure you have nice clean switching on your Input Coil. You need a Voltage Source that you can turn up, this is important to see the effects.
I have coined a term: Delayed Conduction, I have many hundreds of very detailed articles on my Forum: http://www.aboveunity.com, please use the pages there for reference! Please use: Builders Guide to Aboveunity Machines for extra help!
Remember: Greater than 90% of the time, your Input is Off, this means your Output should be Off, there is no way for your Output to be On is there - Well yes, this is where Science has no proper explanation for whats occurring! One of many gaping holes in Electromagnetics! Let me tell you something very important:
   1: The Change in Magnetic Field Creates a Voltage!
   2: The Opposition of Magnetic Fields Pumps Current!
   3: The term Magnetic Fields is Interchangeable with Current, as a Current is the same thing / Creates a Magnetic Field!
Your Coils must be Loaded at all times, or this will not work! It is advantageous to think: Action, Reaction and Counter-Reaction!
We have a Historical Record to support Asymmetrical Regauging, as long as one can get the Potential, Voltage sufficiently high enough: I = V / R, then your machines will produce: Above Unity Results!
Don Smith:
https://www.youtube.com/watch?v=4qqQarHd74s
The MEG Team:
https://www.youtube.com/watch?v=no50_5iSr2Y
Tinman:
Quote from: tinman on June 25, 2015, 08:25:39 AM
What-you mean like the below scope shot's?
First scope shot before the diode.
Second scope shot after the diode,and large cap removed.
EDIT: Below, see Before and after Diode.
Graham Gunderson:
https://www.youtube.com/watch?v=aQVhMu2FzSg
I have done a video series, to try to explain Partnered Output Coils, the effects, what to look for, how to solve problems and how to make the Coils Act and React together in an advantageous way!
   1: https://www.youtube.com/watch?v=VUemDvugl4I
   2: https://www.youtube.com/watch?v=8LtTerstCxU
   3: https://www.youtube.com/watch?v=SWlLiiIyUOw
   4: https://www.youtube.com/watch?v=k5RoEnmDrR4
   5: https://www.youtube.com/watch?v=sTr6dxD61uw
   6: https://www.youtube.com/watch?v=fFIgo7pj9bY
   7: https://www.youtube.com/watch?v=pKFo4dOW4UU
   8: https://www.youtube.com/watch?v=tUaLp0E2L3s
   9: https://www.youtube.com/watch?v=Gs_e_aU5loc
   10: https://www.youtube.com/watch?v=DdwNiaEuUrg
   11: https://www.youtube.com/watch?v=CRduG2PNIgk
The Sawtooth Wave Form is the defining Energy "Generation" Waveform! Please, always keep this in mind! Think in terms of Energy "Generation"!
You need to think in terms of Symmetry vs Asymmetry! A Symmetrical System can Never Go Above Unity! Your System needs to be Asymmetrical, this is a requirement to be able to "Generate" excess energy beyond the Unity Boundary! Its worth Bench-Marking your machine in Transformer mode, making sure you have around 80% Efficiency at least. Then anything above the 80% mark you can verify, has entered the System beyond the Benchmark value!
As I have shown for many years, Partnered Output Coils must oppose, must Buck each other, there is a specific Polarity to this and the polarity needs to be right. Then you need to focus on the "Generation" Phase, and maximise that phase, remember: I = V / R, Ohms Law. Keep in the back of your head, nearly all the Energy "Generation" Phase is done when your Input is OFF! Thus the short Duty Cycle.
NOTE: Your Machine Pumps Current for almost 100% of the Cycle, but your Input is only on around 10%, or less, so > 90% of the Cycle, you have Energy Output, Energy Output when your Input is OFF, this is significant!
If you only take one thing from what I have posted, please take the following sentence:
Its all just an Understanding, think Asymmetry, forget Symmetry. The Magic happens when you break Symmetry! Action, Reaction and Counter-Reaction!
I hope we get a good response from everyone! Good intentions bring forth Good Intentions, but also brings not so good Intentions, thus why we will Moderate. Please think twice before posting.
Please Remember: This is a Builders Group, if you are not building, then if you can make sure you only post useful, serious discussion, you think that would be helpful for others!
I would like to personally Invite Tinman to join us, that is if he wishes.
Best wishes, stay safe and well,
   Chris Sykes
Best wishes, stay safe and well in these dire times,
   Chris Sykes
