THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
AlienGrey
Quote from: stivep on August 07, 2023, 11:01:48 AM
Tell me   what is not right?
- By the way Kapanadze is not based on energy of magnet.
Kapanadze is based on energy transfer from Schumann waveguide unless found - not.
Dr James Corum explained  energy transfer from A to B, and I explained energy origin and its transfer but audience is lazy enough to try it.
Wesley
I dont understand. In Don Lee Smiths book he says it's magnetics produced in a wire 'Right hand rule' is sqare and volts times frequency is important. To find out more read the excerpts on the intrenet links, look it up.
It's an expensive book do you think it will sell ?  more than my pocket money.
stivep
My friend we are talking about  permanent magnets now,
and  energy  stored in the  magnet.
Nothing more than that.
Find me what is wrong in my explanation here:
https://overunity.com/17252/the-rant-room/msg581009/#msg581009
Wesley
stivep
and now please consider all cost and energy used to  create magnet.
first we need to make iron bar.
Iron has an embodied energy of 20-25 megajoules per kilogram(MJ/kg),[2] which is the energy required to extract, refine, and process it.
that translates to : 6.9 kW per kg of Iron  used for  permanent magnet.
add to it  500W  in period of  0.001sec to magnetize it .
The total amount of energy used  is equal to : 7.4kW to create 1kg of  iron based  magnet.
1 millijoule per second (mJ/s) is equal to 0.001 watts (W).
1 megajoule per hour is equal to 277.8 watts.
1 megajoule per second (MJ/s) is equal to 1000000 watts (W).
1 megajoule (MJ) is equal to 277.8 watt-hours (W*h)
If we say that Holcomb found some magical way to extract  all that used energy without losses then
Your 1kW/h microwave will work for 7.4 hours
and after that will be unused forever.
That is the real entire nonsense  of magnet based  self-powered magnetic motor based concept.
Wesley
rakarskiy
Holcomb has no permanent magnets, only electromagnets.
Making a magnet is metalworking from mining, melting and forming a bar. It is not an energy indicator of the formation of the magnetic induction vector. The magnet is started by a high power pulse, subsequently the magnet generates magnetic flux without an external source. Searching for magnetic flux storage elements will only lead you more into a dead end. Magnetic field cannot be accumulated, only induced, excited.
stivep
Quote from: rakarskiy on August 07, 2023, 12:00:45 PM
You are right  Magnetic field cannot be accumulated, only induced, excited.-if we use word "accumulated"  in broad sense:
QuoteA magnetic field is a vector field that describes the magnetic influence on moving electric charges, electric currents, and magnetic materials.
https://en.wikipedia.org/wiki/Magnetic_field
So what the energy  in Holcomb  comes from?
Please specify it step by step so we are on the same page.
Wesley
