THE RANT ROOM
Started by ramset, April 25, 2017, 04:30:05 AM
rakarskiy
Quote from: forest on August 08, 2023, 05:58:00 AM
A body remains at rest, or in motion at a constant speed in a straight line, unless acted upon by a force.[/li]
[li]When the forces acting of body are equal in magnitude and opposite in direction then law 1 also apply[/li]
[li]This is true also for Lorentz force[/li]
[li]
[/font][/size]
Do you agree ?
The Lorentz force is the force with which an electromagnetic field acts on a charged particle, or, in other words, the speed with which a linear momentum is transferred from the electromagnetic field to the particle.  The Lorentz force is the force with which the electromagnetic field, according to classical (non-quantum) electrodynamics, acts on a point charged particle.
The formula for the Lorentz force takes the following form: F(L)=qE+vB, here: V is the velocity of the particle; E and B are the field strengths - electric and magnetic, respectively.
The question is how to apply this rule to the conductor, which is placed in the stator slot, or is in the transformer window at idle speed?  Generally it is a tie to the electron, which is first in the conductor and it is then chased.  What is this nonsense that has been fed for so many years. Electrons move in the cross-section of the conductor with the drift velocity, and it is 0.6-0.8 mm per second, for 1 minute electrons will pass 6 cm, for 1 hour 3.6 meters. And when we turn on the light on the switch on the wall, the light lights up instantly It's just that the mechanical model of gravitation as the primacy of the world order is taken as a basis. But gravity is a special case of electromagnetism.  If gravitation is primary, name the gravitational spin permeability of vacuum.
And also by the Lorentz force they try to balance what is not balanced, for observance of the Law of Conservation of Energy even more nonsense when you start to penetrate into the essence.
seychelles
MAYBE I AM OUT OF CONTEXT. BUT WE SHOULD ASK TINMAN TO CHECK THE VALIDITY OF THIS ONE.
https://www.ecogeneration.com.au/australian-entrepreneur-creates-fuel-free-power-generator/
seychelles
OR MAYBE SUPER LANCA .
Quote from: seychelles on August 08, 2023, 02:32:29 PM
Hello hyper-seychillian,what is going on ?Too much summer,too less beer ( and ..,You know :  :-* - partner)
is Mark Dansie alive ?
https://coldfusionnow.org/revolution-greens-mark-dansie-on-transition-technology-lenr/
http://revolution-green.com/gravity-powered-motors-free-energy-devices/
Can he,if alive,doing some research,visiting them in Australia ?
All the Best wishing (and much sun radiation on the cells ) from south-west Europe
OCWL
kolbacict
Quote from: lancaIV on August 08, 2023, 01:55:58 PM
I would think : Laplace force ! Not ?
wmbr
OCWL
Maybe Laplace,maybe Ampere,I don't know. But the mechanical energy of vibrations increases, this is obvious. Oscillations are made at the frequency of mechanical resonance. If the permanent magnet contains no energy, this should not be the case. I have only one explain.
The vibrator is very old, and the permanent magnet present in it has demagnetized, and the system has gone from perfection.
The current consumed by the coil is even reduced with magnet.
