A3C & X-MAGNETS AND PMF.
Started by ageofmagnetizm, May 19, 2017, 08:07:51 PM
ageofmagnetizm
Very nice Carroll,
I still need to find time to read through you work which appears
to be matching my interests, but from the very entry point of learning
it is clear that you are real user contributing to both of ours communities.
Understanding of profile page of users help AIs to indentify suspicious troll,
because that trolls do not care about profile and quilkly mokking one, usually
copying profile of other users with several changed letters,
and they never develop own profile instead just crawling and trolling.
Carroll, I have cleared youd buddy status and expect you constructive contribution
to this disscussion, only please - speak for yourself because if you blame me
on behalf of somebody then it can happen that I ignore you comments because that other
person is already labelled as "ignore it" and I do not spend time for reading both posts.
I still wayting for credetials of Gyulasun and untill then his status remains same suspicious.
gyulasun
ageofmagnetizm,
Your 'credentials' were immediately defined the moment you demonstrated your using a voltmeter
in series with a load and not in parallel with it. Of course, you do not have to know the internal circuits
of a voltmeter but how to use a voltmeter is a basic knowledge if somebody wants to prove something,
especially when his claim is having a 1000% efficient generator. You pretend not to know about internal
resistance of a voltmeter but what is worse: you grasp for everything not to demonstrate
a correct load test for your generator.
My credentials? Just look up any of my posts say last year, 2 or 3 or any more years of my earlier posts.
I certainly do not have such blog pages you are showing but let me ask: what good is there without proving
the fancy claims?
You have a nice mechanical rotary setup and the principle you show certainly works, it is able to convert
mechanical work into electricity.  However, you have still not proved the "hyperefficiency" of that setup,
you have not showed any correct load tests.
You have measured DC resistances of generator coils and DC resistances of some loads and also measured
the UNLOADED output AC voltage and then you calculated the output power numbers by using P=V2/R
You base your output efficiency claims on such calculations, not on correct input and output power measurements.
This is what turns out from any of your blog pages where you include efficiency numbers.
It is ok you do not believe me but I am not the only one objecting your measurements.You have placed yourself into a rabbit hole you yourself dig for yourself and now you are asking for others credentials?   LOL
The only way you can climb out of the hole is to show correct load test to prove your 1000% efficiency claim.
Gyula
citfta
Ageofmagnetizm,
I looked at your page you linked to.  You have some interesting designs for your generators.  BUT THEY MEAN NOTHING WITHOUT PROPER MEASUREMENTS!!!
You have wasted several pages of this thread and lots of time doing everything to avoid taking proper measurements.  In order to know if a generator is efficient we have to know two things.  We have to know the input power to whatever kind of device is turning or powering the generator.  And we have to know what the power is that the generator is putting out.  With those two pieces of information we then calculate the coefficiency of performance or commonly called the COP.
In electrical use power is calculated by multiplying the current times the voltage which give us watts.  You have not done any measurements that give us the voltage and current being supplied to your load.  So we can't calculate the power coming from your generator.  We also need to know the power going into your generator and I don't believe you have shown that either.
As I posted several pages ago, you may have a very efficient generator.  I am NOT saying you don't.  What Gyula and myself and others have said is there is no way to know because you keep refusing to take proper measurements of what you do have.  If those measurements prove what you claim then you will surely get the recognition you apparently are so desperately seeking.
Asking for any further credentials from Gyula is an insult to him and those of us that respect him.  His credentials should have already been clear to you when several other members of this forum told you how much he is respected.  If you went to a local doctor that was highly respected by the other members of your community would you ask him for his credentials?  That is both insulting and shows a real lack of good judgement.
Please just take the proper measurements so we can see what you really have.
Respectfully,
Carroll
ageofmagnetizm
Carroll,
Inputs are taken from information provided by manufacturer of drive as follow:
Accu marking and manuals say 10.8 volts 1.5 ahmpers and 16.2 watts maximuums,
and shaft 15 N/m max.
Voltage and resistance are displayed on DMM and one can interpreting them as wishs.
Videos were releasing to produce increasing pressure on potential partners which were
targeted by personal emails (not on forums), once targeted objective are achieved then there
no need to release valuable information and betrade trust of partners.
Hence I have neither reazons no right to release anything else other than sheduled by ongoing R&D,
Hence I only can discuss what is already published and can not discuss what will be published later.
Before this discussion was interrupted for two weaks, - on many discussions were suggested
that if loads will be connected to generator than currents of stator wil induce magnetic fields deccelerating
magnets of rotor hence applayed drive will be slowing RPM because of insufficient power input.
Videos showing testing with different loads have produced sufficient prove of conception on
doesends of dicussions except here...
If gyulasun refuses to provide his credentials personally than his status remains unchanged
and I shall ingnore his posts as I ignor adds surrounding posts which are valid, hence:
GYULASUN -- PLEASE STOP POSTING HERE FOREVER. NEVER POST HERE.[/size]
citfta
Well, after five pages of nothing but blabber it should be quite obvious that ageofmagnetizm has nothing worth looking at.  He has made every excuse under the sun for not making proper measurements of his device.  The only logical conclusion is that he knows his device is nothing special but still hopes to convince those that don't know any better that he does have something special.
Ageofmagnetizm, you might as well move on to another forum because you are done here.  Every time you post your foolishness and attacks against well respected members of this forum I WILL post a correction to your false claims and attacks.  I don't know how much the oil companies are paying you for your false claims but I will continue to expose them as false each time you post them.  Your attempts to mislead others will not work here.
Carroll
