Overunity Device by Tanju Argun (Moderated)
Started by gotoluc, June 23, 2017, 06:28:51 PM
Tanju
Quote from: popolibero on June 24, 2017, 12:23:28 PM
Hi Tanju,
please correct me if I'm wrong. The battery is pulsed to the C2 cap.  C2 is the supply (pulsed)of the Bedini SG type motor. The output of the SG, which you configured in boost converter mode (as opposed to standard SG), goes to the output cap feeding the leds.
What I don't understand is how C2 is supposed to power the SG the way you connected it? According to your schematic the pos. of C2 is pulsed to the pos. of the output cap, while the neg. of C2 goes to the pos. input of the SG..
thanks,
Mario
You are right That drawing was old version and there are some mistakes . I am working on the latest version.
Tanju
Quote from: icarus on June 24, 2017, 12:12:36 PM
This part of your code: maybe there is something wrong.
Read0(), Read4()  and Read5()   are not defined, so I think you mean that way:
    vin0=analogRead(analogInput0);  //reading input pins
    vin4=analogRead(analogInput4);
    vin5=analogRead(analogInput5);
I have not included the Read subroutines because they are just for measuring the battery and charge voltages  has nothing to do with the gist of the matter,
Tanju
Quote from: gotoluc on June 24, 2017, 12:09:36 PM
Thanks for the reply and confirmation. But I don't understand why your LED's are behaving differently (no heat) since they are connected to a continuous DC source!
Are the LED's connected in Series as you mentioned they are 28vdc?
Something is not right
Luc
3 LEDS in series across 80 volts and there are 7 parallel branches So I must see 7 times .7 Amps = 4.9 AMPS, but I only see 0.3 Amps . But many people are referring to cold electricty as "Unmeasureable"
May that be the reason???
Tanju
Hi Tanju,
thanks,
Mario
Such mistakes occur when you build a circuit and later to draw a schemati for it:)))
gotoluc
Quote from: Tanju on June 24, 2017, 01:17:49 PM
Thanks for confirming your LED array connection.
I've been building and experimenting with this stuff for the past 10 years. I've built Bedini, Joule Thief and mostly my own ideas with electromagnets and permanent magnets in hopes to achieve OU.
To date nothing has proven OU or any new kind of electricity. However, even though I haven't found anything better then what the established science has put forward I'm still open to finding something I may of overlooked and why I invited you here so we can hopefully all learn something new if that may end up being the case.
I say it that way because to date there has been no OU claim that hasn't ended up being an error of some kind and hope this is not the case with your device and why we need to question your circuit and measurement methods.
I hope you understand this is nothing against you but what we need to understanding what it is that is different in your device compared to all the other devices we have seen come and go over the years.
I would strongly suggest you find a resistive load instead of the LED's to try to get to the bottom of this output measurement problem as I don't believe cold electricity would cause this. Maybe a curling Iron, toaster, electric kettle would work as a resistor of correct value to stay within your voltage range. Please try and report your findings.
We appreciate your help and sharing
Luc
