Clarence replication of Barbosa and Leal self powered generator
Started by casiano, August 10, 2017, 11:16:51 AM
AlienGrey
Quote from: TinselKoala on August 13, 2017, 05:55:09 PM
Well, Nelson, perhaps I owe you a small apology. Perhaps. Someone gave me a link to the manual for the US version of the power meter you used in that video, and perhaps I was misinterpreting the "overload" 0 watts message where it was appearing in your video.
To settle the issue, can you please perform the following simple test that someone else suggested. Simply connect a 1 amp fuse in series between the wattmeter and the White Box, then run the vacuum cleaner on the output of the White Box as before.
If there is truly "0 Watts" drawn as the watt meter suggested in your video, then the fuse obviously won't blow as the vacuum cleaner runs at full power.
Yes a damn good idea, any chance of a new video Nelson showing the fuse, many thanks.
AlienGrey
Quote from: nelsonrochaa on August 13, 2017, 03:27:57 PM
Hi AlienGrey,
I wish to say that i really don't care about what some people could say or bring to table related with any of my videos where i made my own personal tests , i just can't resist answer sometimes when some persons make assumptions and try find all reasons to justify everything like they know everything what is happens because seems the don't understand.
First off all and is a big difference  between me and some of this persons , i don't earn money by sell or promote by my own some of my systems that i shot in video to youtube to a wide public, but i prefer in that way because no one could accuse me of fool anyone or sell any information about any of my tests or how to replicate them.
The meters used was the best  i have available in that time "some years ago" but they are commercial meters and maybe all that meters used are only crazy giving crazy data :)  maybe  .....  like some months ago happens with some experts guys of this forum when they try make some measurements with professional scope units and all necessary rules in a particular system and they measure OU in their own tests. could happens :) shit happens :)
The other point is that older videos are only tests i do myself and not to community in general . I'm not like some persons that only like promote their own videos trying to earn some dollars and some attention to elevate their ego , i prefer maintain myself in background mode, and talk with people that choose by their own ask me about in particular way , and that make a big difference between me and someone that want try cheat other person .
Antijon,
I really don't know if Barbosa Leal system  works or not because the circuit that i show is a bit different and don't work under same principles , i just could talk about my own tests and my system ,  not for the other's project.
That particular system is not overunity even because is not self looped (seems imperative to some )  and only use a way to use reactive power to reduce the final bill of electricity , but seems is illegal like i was informed a few years ago by the electrical company provider departament from Portugal when i conducted that tests years ago  (In German is not allowed too . I was warmed about possibles legal issues if i continue use this system directly to grid , and that make me advance to  a different approaches. So i that way i could not continue with tests on this particularly circuit .
I just could say when is used a inductive loads this particularly system act different instead a resistive load , and that is visible in power factor values in smart meters .  If a inductive load is connected and the power factor is near zero for sure you know what it means :) .
Like i told in begin my videos are only my own tests ,only with a particular value to me , without any intention of promote any particular goal .
cheers
Nelson Rocha
Nelson many thanks for you truthful answer. ;)
Void
Quote from: nelsonrochaa on August 13, 2017, 05:12:26 PM
Hope you become clarify about what you ask .
Hi Nelson. Thanks for the comments. Yes, I was referring to your device from a couple of years ago.
You are doing really well with your research. Sorry to hear about the legal issues. Yes, probably better
not to discuss about such things then.
By self running, I mean a device which does not require external power input like from an external
battery or whatever once it is running, and will continue to run as long as you leave it running, as a
portion of the power that the device produces is used to power itself.
Good luck with the research!
All the best...
antijon
Thanks for clearing that up Nelson. Although I still don't understand the drop in current for a resistive load. Unless some of the current is bypassing the meter when ground is attached.
Looks like your radiant box is based on your pancake coil. https://youtu.be/aEZSCNHDYJs  ::) does the gain have something to do with a bifilar having low reactance, and a normal coil having high inductance?
Hoppy
Quote from: Void on August 13, 2017, 06:59:40 PM
All the best...
Agreed. This is basically my understanding of a self-runner but clearly there are other opinions / understanding. With regards to satifying investors, the power triangle calcs will decide validity of any claim that a device is working ouside convention.
