Magnetic Gravity Wheel Attempt
Started by FreeEnergy, November 23, 2006, 10:26:59 PM
pese
the ball will never "pic up" from the magnet (if  horizontally)
the magnetism-forces are only around this magnet.
Think about :
With liquids in tubes , its a way that floating quicklier that
an steel-ball start to roll .
GDP
gyulasun
Quote from: FreeEnergy on November 24, 2006, 06:43:27 AM
all the balls are at correct position. if you take away all the magnets and leave the wheel alone the wheel will be at equilibrium just like the picture.
OK, I agree with this. I edited your picture by numbering the balls from 1 to 4, sorry for the poorer picture quality.
In order to have all the balls in the positions you show, the wheel should rotate clockwise, ok?
If you accept this, then let's rotate the wheel a little, by 5 degrees only towards the right. What happens?
Ball #1 starts immediately rolling towards the end of the now slopy (in the 5 degree tilt) arm and got stuck by the magnet.  Agree?
Ball #3 would start rolling the same way in its (also 5 degree tilt) tube towards the center but in order to do so this ball should first escape from the attraction of its magnet there.  Agree?
If you agree, this is why I say that the magnet retards the movement of the ball so it works against wanted rotation.  In fact, ideally ball #3 should be positioned at the center the moment it was at 90 degree turn earlier when it was at the place where ball #4 is shown now, to help rotation the most efficiently.
Please comment.  If you say that your wheel rotates counterclockwise, then the same would be true for ball #1 wrt escaping the attraction of its magnet and move towards the center.
Gyula
pese
in shown position it cant start!
if 2 balls  #1 and #3 are starting from inside
both runs outside in same time .
than also not more rotation
