Multisim shows once again overunity with differant setup 60.000 times ou
Started by indigo22, August 13, 2017, 10:42:51 PM
Congratulations! You've proved once again that Garbage IN results in Garbage OUT.
Your "wattmeter" is measuring two different branches of the "circuit" for its V and I values. This is like computing "miles per gallon" using the distance travelled by one car, and the amount of gas used by a different car on a completely different route.
indigo22
Tinsel i know this setup was not in your schoolbooks, i messure everything right
and if your noot openminded and listen to what i have to say and learn from it then you should better leave this conversation
Notice that the "power" indicated on your wattmeter is NEGATIVE. What do you think that means?
Do you know the difference between a Source and a Sink?
https://en.wikipedia.org/wiki/Passive_sign_convention
cheors
I don't speak about the shunt inside the ammeter, I mean your secondaries are shorted, upper wire connected to lower one. That's  a "courtcircuit" in french in the text !
indigo22
yes i know but if you had listen to me in the video i explain that i do that intentionaly
to create 2 north poles aka a buckfield in the centre of the coil sow plus comes in from the left plus comes in from the right
in the middle you have your plus and minus right in the buckfield where the most power is, why you think they call it a buckconverter
with that setup it's plus to plus sow i don't use any current 0 amps
i just use it as a magnetic bias at the same time i'm capturing the radiant spike from the collapsoing filed of the first winding
that commbined is pretty impressive
i would have liked more layers of windings in the sim but this is the best i can do for now
i combined the magnetic bias with the collector bias
if i would wind som right now it would look som like diz
