Rotating stator and rotating rotor
Started by justawatt, August 14, 2017, 04:14:11 PM
justawatt
hi i came across a motor where rotor and stator of motor rotates at same time ,where now the motor is more eff .
now there are motors in the market which are 99 % eff where only rotor are rotating , if we can rotate stator also ,we can have motors more than 100 %
Proof of concept
DC motor http://rotatingstator.com/index_eng.html
And for induction motor
Безопорный двигатель 1. Такого двигателя не видели.
https://www.youtube.com/watch?v=xBWKi5k1zCQ
some more info
https://www.youtube.com/watch?v=8Sle8xUWtNI
http://www.google.co.in/patents/US20060125243
indigo22
1st answer
bad idea look at searl project 2 explain simple you want a coil witch produces a magnetic field by putting voltage and amperage on the coil
that produces the tap. as a metafore take a bicicle put it upside down and tap the weel
you need less energy with the same effect of the energy, when you use dc your killing the dipole
3 fase motors and regular dc motors Always have a green yellow wire to ground it, that all the radiant energy going to waste
you wanna use pulsed dc to tap it
i used to pulse moving stuf but came aware of solid state
first by Thomas Bearden the college of John Bedini the MEG
then i have buildid my own coils and start pulsing them
2 newtonn yes thats overunity but in a small scale, they have better setups look up perminant magnetic motor perendev 8)
indigo22
perendev
they somehow figure out how to either shield 1 side of the magnet or they produce them like that not realy sure
think in your old big pc's hardrives is mounted with a shielding plate
anyway here https://www.youtube.com/watch?v=PFGiWiXMHn0
Bertoa
The counter rotating rotor and stator in a motor is a very interesting setup to explore. At the moment I am experimenting
with a permanent magnet motor build in that way. At a later stage I hope to publish some results concerning in/output power,
efficiency, torque and construction.
Justawatt, when a motor with a rotating rotor and stator should be more efficient than 100% it was already invented 100 years ago.
There are enough patents on that theme. By the way, why not talking about counter rotating rotors. In this case the stator becomes a rotor.
To make it more complex; why keep it only by 2 rotors?
