Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
Low-Q
Quote from: vikram_gupta11 on December 05, 2017, 10:32:19 AM
Hello sir,
But in this device this will not happened .spring generator means if I use a wall made with flexible rubber and this rubber wall hit a piston generator mounted outside from the device then I don't thing that it will not bounce back.it will definitely bounce back.
One more thing if I use two piston generator mounted on the both end of long tube then the ball will also bounce back after transferring it's kinetic energy to the piston.
No need to worry about bounce back of ball as the counterweight will work to get the seesaw it's original position as there is no hurdle in it.
I have already mentioned that the system will get back it's initial position if ball fall down or doesn't but interesting point is kinetic energy of ball.
Now you will again raise a question regarding load that the load will create problem but ball is free to move in the tube so ball and generator will work separate ly .there will be no hurdle regarding load.
How can you get energy out when the "spring" use all its stored kinetic energy to bounce the piston back?
Vidar
vikram_gupta11
Hello sir,
It is very simple if spring has stored all kinetic energy then it will release it also when ball will reversed as ball is free to move.the best example is" Hand power fan" to understand it.
Low-Q
Quote from: vikram_gupta11 on December 05, 2017, 10:55:16 PM
Hello sir,
Ok, but that means you cannot take energy out to run anything useful. The stored kinetic energy in the spring is not more than the kinetic energy applied from the piston, right?
So to achieve over unity, the spring must by magic create energy or pick up additional kinetic energy from some, yet unknown, energy source.
You must first understand that conservation of energy is constant everywhere in the observable universe. Then you must try to understand how to create energy from nothing. I believe that will be a very hard task that takes literally infinite time to figure out. I think you must travel that Sanatana Dharma (सनातन धर्म) to achieve over unity some day - well, actually not one day since that forever lasting road has no end :-)
Make a replica of the "device" below. With some modifications, it might be able to create energy instead of the world.
Vidar
vikram_gupta11
Dear Sir,
I have clearly shown and proven the kinetic energy of falling ball and you say that from where it will come.
If spring based piston generator doesn't work in the device then all Hydropower plant must be shut down as no energy will be generated.
The only difference is between this device and hydro power plants is input energy.in Hydropower the output will be less than input but in this mechanism output is more than input.
The spring can store 99% energy so I preferred the spring based generator.
But I clear your doubts about using coil+ magnet generator.
Ok.this generator can be also used in it but use this generator only halfway of tube.
Suppose if tube length is 120 cm then only 60 cm in middle of tube.
You will found same result.(overunity)
Edit: there will be need of very less kinetic energy in this mechanism to reverse it.you say that the coil+ magnet will work to slow the kinetic energy,yes you are correct but once ball pass the coil then it's kinetic energy will be increased again and this energy will be sufficient to reversed the device.
vikram_gupta11
Dear Sir,
I have already studied very much about "Dharma and Darsan." The image you send me is of "Natraj".a God of energy destroyer not creator but I send you a image see it .you will get surprised that my device is very much similar to that replica.
Lord Vishnu an energy creator.
