Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
This is not a particular image.just type "Lord Vishnu in Khseer Sagar". The image shows if Lord Vishnu is sleeping in this position then energy is being created and billions universes are being created.
vikram_gupta11
I would like to insist on one point that mass is important in it .so the device will also work in that case if we use coil + magnet generator but mass must not reduced.as mass is important factor in it.
Low-Q
Quote from: vikram_gupta11 on December 06, 2017, 11:25:27 AM
I guess I have to build one and measure input energy and output energy. Your system is simple, so it should not take long.
I already have a structure with a small flywheel with low loss ball bearings. I got to mount a seesaw on that one, with counterweight and a tube where the mass is falling down into.
Vidar
vikram_gupta11
Sure,test it.there is clear cut Overunity in it without any flaw.
vikram_gupta11
The sketch is clearly proving overunity in this mechanism.
Consider that box are weight less so input will be same in both cases but kinetic energy of ball.?
No doubt kinetic energy will be increased in long tube.
Input less output more.
