Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
The force with this translucent force resides fully with the earth.
So have an open circuit to take advantage of this.
Heat molecules also tap into the earth's power so the heat pump perpetual process is archived.
Like the same with ions static power connected to earth's power advantage same with heat where the earth produces ions static same with heat and the sun and the like.
That is where you have to tap into other wise you won't have the correct force which I have been on about because the earth is already connect to Zpe vaccum so you don't have to work out how to achieve that in a closed circuit.
It won't work in a closed circuit but in an open one to extract earth power then it works and in that open. Circuit you have a translucent force to play with.
Instead of matching the earths resonance to achieve the desired effect i have now got this force internally in  a circuit in what i call the ceiling extracting zpe vaccum energy and is defiantly knowing it is drawing energy from vacuum , if you did my method with your current knowledge of electric it wouldn't work as in not doing my circuit but to tap into the earths power the conventional way it would have no ceiling of torque(to get work done but this is under unity) but instead of that i am tapping the accelerator going 100 per cent so it gives excess energy, with your reasoning is it credible that it will give excess energy or not with your understanding of the force going full 100 per cent?
Its like the same reasoning in saying we need zero friction for it to work perpetually(like an atom spin going round in circles that is zero friction) but there is a method where it doesn't need zero friction because it is in the process and same with this 100 per cent process of the energy.
So using simple physics yes we need zero friction for it to rotate and if you want a force to give excess power we need it to be 100 per cent if only i could put it into words.
50% efficiency is needed because it is a half cycle of energy this will achieve a friction less environment and with the potential of that energy using this simple understanding i know full well it will give excess power due to the nature of it, it is the translucent effect image the translucent effect you see it and that is how it gives excess people.
so you see it is very clear with no friction is will enable it to do this but only how to achieve it? same with it being very clear to me with the accelerator effect going 100 per cent.
At best with these overunity machines it is using the dead exact same principle as the heat pump in your fridge except it is solely extraction of energy and in that energy is the zero point force and you can excite it to tap into zpe energy simple.
So instead of trying to replicate or understand i am afraid the answer is in the heat pump.
This translucent force propels the  acceleration effect.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
We can control acceleration via the translucent force.
I know full well about the heat pump achieving the desired effect self-perpetual actually isn't a pipe dream it is reality.
I can see an electron beam/spin clearly demonstrating the impossible accelerator effect just by using the earth since the earth is already wired for it and at very least can be used for a warp drive like the em drive but the part i couldn't prove is the translucent effect behind it, got interrupted to say it isn't perpetual motion from somebody.But they will discover things like a polar opposite Zpe force because Zpe is tied in effect with the acceleration effect of earth.
lltfdaniel1
My understanding of the acceleration effect has caused an earthquake in science community.
There is an unbalanced force where it states everything as being equal attraction right so with this you can control it with a balanced force, the unbalanced force breaks that perception which propells the acceleration like an unbalanced wheel.design you know but nature has one that actually works other wise no accelerator effect.
The acceleration effect is a species of the natures own unbalanced wheel effect so it runs perpetually.
Not out of nothing it implies that it cannot run perpetual Lt, you cannot make energy out of nothing,unless you start to view the vaccum as having energy and in this energy is power to create it has to have energy of Zpe vaccum wouldn't work or go off to infinity so what causes it to go off to infinity where it has no power?
So if the vaccum has no power to your reasoning what other idea is there?
You would think obviously it has to have power to do work(go off to infinity) at the very least even if you view it not to be a perpetual force that is.
Science view it as to having no power(no energy what so eever in the void/vaccum/zpe so this means it creates power out of nothing(thin air) which isnt accepted in science community( but it does come out of thin air otherwise you cannot extract energy from vaccum/zpe) or no power to create which is illogical stop using that cannot create nor destroy nonsense this force isn't like that.) which destroys the conception of power to create and destroy.
We are using circuits that destroy the process.
I hope you see the contradiction of mainstream science regarding zero point and what i said about it in this post they end up with theory or cannot explain or cannot measure zpe that goes off to infinity.
So zero point the name means energy comes out of thin air(which science doesn't buy) there is evidence which supports me on this for sure about energy to use from zpe, it is a sign that actually zpe is creating power there (where it comes out of thin air regarding the vaccum effect it self that is)
So this zero space means exactly that, make sense or not?
zero space is the opposite trajectory of zpe it self this is what causes the acceleration that i am always on about which gives its effect
Zpe is exact like an over balanced wheel to give a perpetual effect but they dont seem to work like that instead of being equal forces which is what is taught in school.
zpe is by no means a balanced force (out of every species of the balanced understanding) over wise it wouldn't work again or go off to infinity.
zero point is at the end of the spectrum thus isn't a balanced force what   so ever knowing about this zero teractory it is not balanced force, zero is unbalanced like an over arched wheel that is their understanding in that is the translucent effect
lltfdaniel1
So zero point means zero energy where there is no power or power to create.
But if you look up at the upper end of spectrum that is where power to create is as opposed to power to destroy.so the upper end of spectrum is full of energy got it?
I think there would be tell tell signs in science that supports me.
There is a definite opposite to zero point yes or no?
More like power to destroy where energy spawns from the negative vaccum.
But energy doesn't spawn from the negative vaccum but it does with the positive vaccum that is.
But with opposite there is a sucking effect in vaccum where negative zero point energy comes from in the negative vaccum which follows power to create from the positive vaccum.
lltfdaniel1
If the universe started with zero point we wouldn't exist.
Because it is negative end of spectrum..we wouldn't exist. I have a clear understanding that zero point doesn't exist either.
So with negative vaccum there is no force to play with.
They I believe are incompatible forces regarding positive vaccum and negative vaccum.
I can see clearly of why the zero point self destructs and is waste thus it cannot create power(mass less where it doesn't exist and we wouldn't exist and nothing would ever have created the universe) but it can create a destructive power though through the suckion/vaccum effect which follows positive vaccum
zero can point can create an equal force that is understood but there is a perpetual effect of the vaccum effect which isn't widely known
It self destructs whereas the positive self generates.
This zero point cannot sustain it self nor can it self perpetuate and is like a leech , to leech power form the positivee vaccum
This zero point is out-side of the void of creation and thus is incompatible.
I stand to be corrected i do have a correct consensus but am getting to know the vaccum and why it is so.
i think there is blind spot in science they cannot see past zero point.
In nature and every where in the universe it doesn't even use zero point which is the negative vaccum or negative end of spectrum the space between atoms.
I can now see why it is impossible to achieve the effect and why they say it is impossible because of this the universe wouldn't exist simply put, it isn't the first one.
if it is impossible then it is impossible for the universe to begin with.
this less and less effect is self combust.
I can see why it is impossible the core of zero point is impossible by it self this zero point doesn't have work in it.
i can see why i am being laughed at scorned etc i can see it clearly, and can see why they say the accelerator effect is impossible as well.
I can see why it needs to be positive only
THE VOID OF NOTHINGNESS
Suddenly I seemed to be rocketing away from the planet on this stream of Life. I saw the earth fly away. The solar system, in all its splendor, whizzed by and disappeared. At faster than light speed, I flew through the center of the galaxy, absorbing more knowledge as I went. I learned that this galaxy, and all of the Universe, is bursting with many different varieties of LIFE. I saw many worlds. The good news is that we are not alone in this Universe!
http://jahtruth.net/etvisit.htm
As I rode this stream of consciousness through the center of the galaxy, the stream was expanding in awesome fractal waves of energy. The super clusters of galaxies with all their ancient wisdom flew by. At first I thought I was going somewhere; actually traveling. But then I realized that, as the stream was expanding, my own consciousness was also expanding (seeking - JAH) to take in everything in the Universe! All creation passed by me. It was an unimaginable wonder! I truly was a Wonder Child; a babe in Wonderland!
It seemed as if all the creations in the Universe soared by me and vanished in a speck of Light. Almost immediately, a second Light appeared. It came from all sides, and was so different; a Light made up of more than every frequency in the Universe. I felt and heard several velvety sonic booms again. My consciousness, or being, was expanding to interface with the entire Holographic Universe and more.
As I passed into the second Light, the awareness came to me that I had just transcended the Truth*. Those are the best words I have for it, but I will try to explain. As I passed into the second Light, I expanded beyond the First Light. I found myself in a profound stillness, beyond all silence. I could see or perceive FOREVER, beyond Infinity.
* The Truth that he - the Being part of a human+Being - is not human - JAH.
I was in the Void.
I was in pre-creation. I had crossed over the beginning of time - the First Word - the First vibration. I was in the Eye of Creation. I felt as if I was touching the Face of God. It was not a religious feeling. Simply I was at one with Absolute Life and Consciousness.
When I say that I could see or perceive forever, I mean that I could experience all of creation generating itself. It was without beginning and without end. That's a mind-expanding thought, isn't it? Scientists perceive the Big Bang (theory) as a single event which created the Universe. I saw that the Big Bang (theory) is only one of an infinite number of (so-called) Big Bangs creating Universes endlessly and simultaneously. The only images that even come close in human terms would be those created by supercomputers using fractal geometry equations.
The ancients knew of this. They said Godhead periodically created new Universes by breathing out, and de-creating other Universes by breathing in. These epochs were called Yugas. Modern science called this the Big Bang (theory). I was in absolute, pure consciousness. I could see or perceive all the Big Bangs or Yugas creating and de-creating themselves. Instantly I entered into them all simultaneously. I saw that each and every little piece of creation has the power to create. It is very difficult to try to explain this. I am still speechless about this.
It took me years after I returned to assimilate any words at all for the Void experience. I can tell you this now; the Void is less than nothing, yet more than everything that is! The Void is Absolute Consciousness; much more than even Universal Intelligence.
Where is the Void? I know. The Void* is inside and outside everything. You, right now even while you live, are always inside and outside the Void simultaneously. You don't have to go anywhere or die to get there. The Void is the vacuum or nothingness between all physical manifestations. The SPACE between atoms and their components.
* The Force - JAH.
King of kings' Bible - Thomas 1:6 But the Kingdom is within you and it is without you.
1:7 If you will know yourselves, then you will be known and you will know that you are the sons of the Living Father.
1:8 But if you do not know yourselves, then you are in poverty and you ARE poverty.
http://jahtruth.net/kofkad.htm
Modern science has begun to study this space between everything. They call it Zero-point. Whenever they try to measure it, their instruments go off the scale, or to infinity, so to speak. They have no way, as of yet, to measure infinity accurately*. There is more of the zero space in your own body and the Universe than anything else!
* How could a finite object measure infinity? How can infinity be zero, except in man's illogic? - JAH.
It is hard to explain...i can see why, the only thing that comes close to an unbalanced effect is the way the vaccum is the vaccum.
Well at end of the day my previous comment about energy spawning from positive vacuum seems to be right.
But to be honest with you i thought energy could be generated by negative vaccum or be self propelled between the two forces of the vaccum energy which cannot and i seem to think you need to match positive(vaccum) with positive(vaccum) to achieve a perpetual effect(using a circuit current flow wire prehaps? a wire that only allows one force to flow through it instead of two and replace the two polarity and use it with the zpe vaccum so postive and postive both together on one end), just a theory and might be wrong.
Also the opposite equivalent of the vacuum is well i don't know.
