Magnet Motor Solved.....?? See the Video Clip on OU
Started by kampen, October 20, 2017, 12:28:14 PM
kampen
@ All,
Have a look at this video clip: Magnet Motor Solved
Is this for real?
MagnaProp
Sorry. I wish it did but everything about the presentation says "run away" to me. But then again I might be one of the government plants that is against free energy and don't even know it :o
ramset
Kampen
not sure about the magnet motor mentioned here.
However years back you built a solar parabolic oil/water heater?
did you ever get any figures on how fast you could make steam?
or how fast to temp ?["Dish size" 1 litre to boil /time ??
respectfully
Chet
Thanks Grandma
kampen
Dear Chet,
I did not made any test nor calculations to make steam.
Doing the Math is far too complicated for me.
But at TUV-Germany in COLOGNE they have tested the Parabolic Dish I made  with 8 segments of high-gloss polished SS-316 steel (diam. 1.300 mm)
filled with WATER and connected to a 120 Liter boiler with a circulating pump the efficiency was rather poor, only 60-62%.
Found out that too much losses on the Aluminium tube-absorber (lenght 1.200 mm) caused this.
Later I have replaced the Aluminium tube-absorber with a CERAMIC heat-exchanger one and used Synthetic oil as medium the same set-up connected to a 120 Liter boiler with a circulating pump the efficiency was HIGH, up to 90-94% on Sunny days.
Unfortunatly at my place I have only ca. 1.200 hours Sunshine in a Year!
Hope this info will be any help.
Greetings, Alex
ramset
Alex
thanks for the reply
And yes Solar has a ruff time in some places with feasibility !
Chet
Thanks Grandma
