Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
benfr
Quote from: lancaIV on July 22, 2019, 08:21:21 PM
http://rexresearch.com/barbat/barbat.htm
Now mr lancafour, I am impressed !
I just took a look at this link .
It is an ABSOLUTELY WONDERFUL EXTENSION TO Rick 's RICK (resonant induction coupler kit) !!!
A MA ZING !
That's the most interesting post around the kit that I've read so far, except for those forumers posting their kit exepriences of course.
mr a.king, too bad you did'nt say yes to my request for an Atelier ;D ! God has been doing that for me right with This !  :D
I do have those many coils due to my successful replication of Rick's kit with cheap cables, so I could be experimenting soon with introducing this Sir Barbat setup to Rick's.
a.king21
Quote from: Void on July 23, 2019, 12:11:04 AM
Hi a.king. Actually from the screen shot posted here, it appears there are coils beside coils beside coils, each coil acting to pass the energy through
to the next coil until the load is reached.
All the best...
Not a very scientific reply I am afraid.
So explain to me how according to the inverse square laws the mr16 is lit at all - when all the intervening coils are also illuminated.
Unless of course Rick's theory that "each coil makes a magnetic copy of the original (at resonance) and retransmits the magnetic field" is plausible.
Methinks some EEs should get a gaussmeter
ramset
I have spoken with Bill  Barbat many times it would pain him to Think people would compare the two.
If it was this easy ,Bill and MANY others would have done it decades ago ..and he is still trying ..[last I heard been a cpl years]
He has a low mass electron theory or something ? he is still trying to prove....He is a wonderful fellow
Aligning 1 molecular layer of Graphene ...oriented a very specific way is what he tries to do ...working at the level where atoms and the gaps between can be seen
Stefan has a mission Statement here ...which inspired for a long time... I suppose it assumes an open source venue will have persons
not coming with secrets [the two are exact opposites]
So here we have a theme which seems to be reinterpreted ??
and many confused members who thought they understood the theme was the first guide ...and then the task [the mission statement]
secrets....or reasons for not sharing or helping or ......doesn't fit with Open source ... successful open source models are everywhere on the internet...
And to my knowledge they don't work on secrets...or half measures, Passion drives them and passionate people .
and somehow in this thread the most passionate here are seen ... ??
what to do...??
Thanks Grandma
Void
Quote from: a.king21 on July 23, 2019, 07:59:46 AM
Hi a.king. I do not see loads connected to every coil in that screen shot that was posted.
I do see lots of intervening coils between where lights are connected, exactly as I said.
As I have already pointed out to you, if coils are operating at or near resonance they will have a stronger
magnetic field around them, but they are reactive components. They are not consuming real power, but
they can pass energy on to surrounding coils, as I have mentioned. In AC circuits, coils and capacitors are not consumers of power
(except due to relatively small resistive and small equivalent losses). The bulbs however are consuming power, and the total energy
coming from the input supply/driver should be divided amongst each bulb, which appears to be consistent with what
we see in the screen shot.
I wish you good luck with it, but it is just not looking promising from what I see.
The setup appears to be acting within normal expectations. If you or someone else can demonstrate
otherwise in a reasonable way, then let's have a look.  ;)
All the best...
P.S. If you have any doubts about what has been stated, then I would suggest you connect up a similar
arrangement and try it for yourself, rather than trying to get other people to do it for you. Then you can determine
for yourself how it is really performing. Make sure you either do proper measurements or self-loop it
so you don't lead yourself further down the garden path based on more wild guessing and misunderstanding. :)
Raycathode
Mr Void an interesting observation and thanks for you technical knowhow in this particular field you have shared.
regards Raymondo
