Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 74 Guests are viewing this topic.
a.king21
Rick made an interesting claim: Resonance is a gain. In a series resonance circuit the input amperage remains the same as the circulating current in  the resonant coil. At the same time the voltage inside the resonant coil goes higher up to 144 times. So a simple V x A = watts indicates OU of course.
So my question to myself was," What experiment can I devise to attempt to prove the claim" ( Notice I am being positive folks).
What experiment can you think of??
Well here it is:
I used the principle of oscillating current  as promulgated by Benitez.
So I attached one leg of the ac side of a bridge rectifier to the high voltage side of RICK's TX  coil and the other leg to earth ground.  Then I attached the positive and negative sides to a 12 volt 7 amp hour battery and it charged very nicely.  I do not have the correct measuring skills to see if there is a gain - but to those interested I enclose a pic and encourage you to do the experiment.
It is 3 am and time for shut eye,  I may develop the measuring skills tomorrow when i have time to think about it.
Oh and I was able to keep the device in resonance as I extracted real power out of it.
I make no apologies for the size of the pic as you need the details.
And it still lit up the RX without diminution........
Meanwhile those unicorns.....
a.king,here lecture ,I give special attention to [0012] "...... undesired(desired !)......" and [0024] "resonance" ?!
https://worldwide.espacenet.com/publicationDetails/description?CC=TW&NR=200727310A&KC=A&FT=D&ND=3&date=20070716&DB=EPODOC&locale=en_EP#
and here ( one time more) :
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=5264988A&KC=A&FT=D&ND=3&date=19931123&DB=EPODOC&locale=en_EP#
60 Watt nominal lamp : 130 Volt x 200 Amperes "cold energy"
  26000 VpiApi / 60 Watt : 433 times the nominal value = "EMP stroke power"
capacitor: stroke power re-/charge pumping process device
hartiberlin
I think a good example of the huge power that the Rick Friedrich circuit delivers is this video:
https://youtu.be/6he58A5xTIQ?t=1562
at around 30 minutes in it, where several high power LED bulbs are lighted up
and the voltage from the batteries did not change during the whole demonstration..
So this is pretty exiting and my friend confirms it in his replication.
Regards, Stefan.
Raycathode
Quote from: lancaIV on July 29, 2019, 04:52:26 AM
Thanks Stefan and yes i did watch the 'clip' but found it difficult to concentrate getting much information with all the back ground and recording noise, perhaps others will collect more, hopefully to share.
One point of interest was the 'host guy in the lense focus mentioned 'negative energy' and put the LED lamp into a beaker of cold water, what most of us want to know is how exactly is 'cold' electricity made ??? and what is it??
this information always appears to be avoided or hidden can some one who knows please explain what it actually is ??
regards   Raymondo.
PS the editor appears to have a problem with CR and LF it appears to mix them up witch is annoying and a never ending circle trying to compensate for :) :)
"cold energy( here not meaning " cold electricity")" is normally "radiant energy" ( specially IR/UR temperature-free emission during the transmission) but stimulating this radiation receiving mass !
https://energyeducation.ca/encyclopedia/Radiant_energy
( tools also L. A. S. E. R and M. A. S. E. R.  )
heat/mass relationship : "... It is not generally recognized.... "
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=6259347B1&KC=B1&FT=D&ND=3&date=20010710&DB=EPODOC&locale=en_EP#
Also important for permanent magnet- free motors and generators !
