Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
tinman
A question for all.
Ok,i have redrawn the schematic,and will explain a little further.
Lets say the generator is a low 70% efficient.
The device is started with the switch in position A
The current is 8 amp's,and the voltage is 24 volt's.
So the power being sent to the motor is 192 watts.
Lets say the motor is 80% efficient,and so the mechanical output from the motor is 153.6 watts.
Our generator is only 70% efficient,and so we would only get 107.5 watts out of our generator,from the 192 watts being consumed by the motor.
The generator is required to produce 8 amp's @ 10 volt's=80 watts
This 80 watts is only 74.7% of the output the generator can deliver for the given P/in
So,the motor is started with the switch in position A,and when up to running speed,the switch is switched to position B
The question is-->what happens when the switch is switched to position B?
Brad
citfta
That is brilliant Brad!  When I first looked at your schematic I didn't look at it closely.  I just assumed you were connecting the output in parallel with the batteries.  Now that you added the switch I looked closer and realized you were connecting the output in series with the batteries.  I am thinking if you get the energizer rewired so the current is higher and the voltage lower the whole system will speed up and maybe go into a run away condition.  Or possibly use a step-down transformer to get higher current at lower voltage and keep the current down in the energizer itself.  I am eagerly awaiting your results.
Carroll
tinman
 author=citfta link=topic=17491.msg513063#msg513063 date=1510666354]
QuoteThat is brilliant Brad!  When I first looked at your schematic I didn't look at it closely.  I just assumed you were connecting the output in parallel with the batteries.  Now that you added the switch I looked closer and realized you were connecting the output in series with the batteries.
Carroll
QuoteI am thinking if you get the energizer rewired so the current is higher and the voltage lower
Already done  ;)
QuoteOr possibly use a step-down transformer to get higher current at lower voltage
I was thinking about going that way,but the transformer is just another loss.
Quotethe whole system will speed up and maybe go into a run away condition.
Brad
Void
Quote from: Erfinder on November 14, 2017, 04:36:44 AM
What did I say....only the ignorant chase OU.....
you don't hear me saying anything about OU.....
Hi Erfinder. I have been following this thread, and I am kind of at a loss as to what
you are up to here. You act like you have these claimed motor/generator OU devices all
figured out, yet you offer absolutely nothing concrete and useful to help Tinman except taunts and insults.  :o
The title of this thread is 'Confirmation of OU devices and claims'. If you believe all OU claims
are 100% false, you could have said that in one comment and there would be no need for you
to comment any further in this thread. All I see from you so far is childish comments trolling Tinman.
If you want to share something useful, then share it. If you don't want to share anything useful, then why are
you commenting here?
