Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 31 Guests are viewing this topic.
synchro1
The SPDT pressure switch at the base of the solenoid syringes would replace the complex commutator and route output to storage too:
The power exchange being equal, this motor generator would be over unity by the amount of inertial force developed in the flywheel.
https://www.youtube.com/watch?v=Hwr7jRg0ykg&t=476s
Imagine the flywheel torque a reciprocal six could generate!
synchro1
The watts of BEMF output channeled to load through the SPDT switch would have to be subtracted from the overall power output of the oscillator if it were not diverted.
The oscillator would generate exactly the same amount of horsepower less as the BEMF recovered in output because it works backwards against the power of the oscillator.
This would be to the degree the Lenz relief from the core isolation subtracted from.
synchro1
Drawing power off by channeling BEMF to output adds force to the generator motor; Just the opposite from an ordinary generator.
synchro1
Everyone remembers Gotoluc's tests with the current reversing magnet coil. Remember the SPDT micro roller switch? Imagine replacing this inventors commutator with a cam lobe and micro roller switches on each side. This would permit us to reverse the current on the traveler coils at TDC on each end for a power pulse, and channel the output to destination as well: Here's a clear example of how doubling the disc magnets on the ends would double the output with the same input.
https://www.youtube.com/watch?v=5EcuuFbSwSg
The most severe limitation of the Newman motor is that the magnet rotor is limited in size by the internal dimensions of the coil core. Sliding Newman's "Big Eureka " coil on a rail would permit the magnets to go the outside and be many times greater in strength then Newman's core rotor. This might quadruple the flywheel torque for the same zero inout.
synchro1
Here's the "Newman Mendocino" with his 800 pound of copper coil suspended by Mendocino levitator magnets with a horseshoe double the strength of the rotor magnet that could fit in the core;This design can benefit from a ferrite coil core to increase inductance even more!
The DPDT micro roller switch can reverse the coil current with a flywheel cam.
