Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Here we see the two coils and magnets: The primary against the wall pulses the ring magnets on the levitator axle, and the second larger coil collects the BEMF from the first between the powerful horse shoe uprights. The scale up of magnet force and coil mass on the center axle is designed to magnify the magnetic field of the center coil to compensate for the lesser amount of BEMF power while delivering a back stroke of equal strength:
This linear oscillator can use a diode and capacitor like Gotoluc, along with one side of the SPDT spring pressure switch instead of Luc's Reed switch. Either way there's a delay between the power pulse in the primary coil and the power pulse in the secondary;
thumbnail
synchro1
Woopyjump's BEMF spinner; Look at and compare the relative size of the coils and cores: These are the same proportions the two coils would need to be on the linear oscillator. The degree of offset from 90 degrees is the delay that would equal the throw for the oscillator.
The linear oscillator would allow us to keep the coils the same size, if we increase the magnet strength of the horse shoe. We can reinforce the field by adding magnets to the outside of the stators while keeping a tight gap for the coil:
The oscillator, although asymmetrical, corrects Gotoluc's imbalance issue.
Click on this Hyperlink below:
https://apis.mail.yahoo.com/ws/v3/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==AHkyJ_cpU-pwW_AcagWVsLmtCIk/content/parts/@.id==2/thumbnail?appId=YMailNorrin
synchro1
1st Mendocino Oscillator Run:
https://youtu.be/2VhQq_utlQg
Looks pretty simple until you consider that there's a live output wire leading away from the pulse coil.
synchro1
                                                               Lynx Joule Motor
The chief advantage of the "Lynx Joule Motor" circuit over gotoluc's is the recycling of bemf from the secondary to the source battery though a bridge rectifier. Luc's circuit fails to pass the gain on. We get a two for one advantage with the secondary, and a third with Lynx's looped charge.
click on this link;
https://dl-mail.ymail.com/ws/download/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==AGXpJiJPzTb7W_E26Qtp4Gyrzsw/content/parts/@.id==2.2/raw?appid=YMailNorrin&ymreqid=816164b5-7d02-ce23-1cfd-39000301bb00&token=zitEzqOML3j84e6ealFTT5U7-km5qEQF52lp7AcCuBYuSfoFz8vQYu01Ebe_f8pg2ITMlv4-3AvnkLQDemZLxHwtsH6_HC8hR_TqMSR7KK7Kq2x236OSj64rSSjwoc6v
