Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
improvement;
Galfenol converts energy with high efficiency; it is able to turn roughly 70 percent of an applied mechanical energy into magnetic energy,
https://www.youtube.com/watch?time_continue=9&v=LhRCOWRJV3w
synchro1
                                               Elastic band counter pressure.
I rebuilt this version of the oscillator to run with a capacitor in parallel with the power source to see if it will continue to run with the power wire disconnected from the source transformer. Look how the rubber band helps balance the attraction force:
https://youtu.be/q6f9FcvIRHo
synchro1
                                                      Increased flyback with magnets.
I've never seen this demonstrated before!
Compare the flyback flashes; First with the magnets attached in attraction to the electromagnet and second; with the magnets detached:
https://www.youtube.com/watch?v=kClQviOvywY
synchro1
Here's Luc's watermark video of amplifing power by sparking across a Neo magnet. In my video we see an electromagnet attached below the Neo sphere; What effect do you think connecting the electro magnet to the oscillator coil and running a recycling diode across the electrodes would have on the EM force field?: Look at the voltage I'm generating off two 1.5 volt AA batteries in series!
The bonus here is that, as I demonstrated in the last video, the magnet not only amplifies the spark, but it strengthens the flyback from the "Electro-Magnet" coil. A third dividend would come from recycling the increased flyback through a diode positioned between the coil wires instead of lighting LED's. It would increase power to send the spark through the Neo magnet on the oscillator armature.
https://www.youtube.com/watch?v=wRWwFxNZZxc
https://www.youtube.com/watch?v=6BDA...n5ayZlb5K_cwaA
What I've been designing here is a speaker in reverse. The oscillator coverts mechanical vibration to electrical power through the "Sono-Battery". This vibration generates electricity. This is the opposite from a speaker that coverts electrical signals into kinetic motion.
This version would simply run with an oscillating "Reed Switch". The "Sono-Battery" can convert higher vibration frequencies. We amplify power three ways. One; We send the spark through the magnet. Two; we increase flyback by attaching the magnet to the EM coil. and Three; We recycle this doubled flyback by looping diode. This would jitter a magnet free of charge on a bell tub with a Gafenol hydro coil.
