Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
                                      Flash camera discharge for sheer pulse.
What effect would jolting an electromagnet with a flash camera discharge have on the force field?
]https://youtu.be/jp-eOLuRLSs
https://apis.mail.yahoo.com/ws/v3/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==AKKaZ95QSWVLXCJzJgLOwGLY3l8/content/parts/@.id==2/thumbnail?appId=YMailNorrin
Connecting the flash camera circuit to the SPDT oscillator would place the sono vibrator it in the "Richter scale" range.
synchro1
2. Optimal design of the coil gun
2.1. Coil gun system
Coil gun system propels the projectile by electromagnetic force caused by Fleming's right hand rule when the electric current energizes the electromagnetic solenoid coils. The schematic diagram of electric circuit for coil gun launching system is shown in Fig. 3. The electromagnetic coil is energized by discharging of a capacitor.
synchro1
Create an electromagnetic coil. An electromagnetic coil is a device that is made up of two distinct yet integral parts: a conductor and a core.[3] In this case, your iron rod will be your core and your copper wire the conductor.
Wrap your copper wire tightly around your core, leaving little to no gaps in your windings.[4] You should leave excess wire at the beginning and end of your winding so that you can connect your coil to your flash capacitor.
Image titled Make an Electromagnetic Pulse Step 3
3
Solder the ends of your electromagnetic coil to a capacitor. A capacitor is generally a double-pronged, cylindrical shaped component found on most circuit boards. Your disposable camera should have a capacitor for its flash.[5] Be sure that the battery of your disposable camera is removed before attempting to solder the ends of your coil to the capacitor, or else you could get a nasty shock.
synchro1
Disposable flash camera coil gun:
https://www.youtube.com/watch?v=E2DBM6lz7q4
The BEMF from the power coil gun can easily loop to the discharge capacitor through a diode wired to an SPDT switch
Rocking the charge in and out of the discharge capacitor is a bit different then charging the source battery with the flyback output.
__________________
